Jumping an OBDI PR3 ECU (integra xsi)
Old Mar 19, 2006 | 07:08 AM
Mag00n's Avatar
Default Jumping an OBDI PR3 ECU (integra xsi)
i have an obdI pr3 ecu and harness from the integra xsi.
My problem is im throwing a code and i really want to see what it is but i have NO IDEA how to jump this.
There was a brown and blue wire taped off together seperately from the rest of the harness which i really thought was it, but when i cross them nothing happens.
ive searched and searched the car and cant find jack. Anyone have experience with this ecu/harness?
Old Apr 10, 2006 | 06:00 AM
Mag00n's Avatar
Default Re: Jumping an OBDI PR3 ECU (Macan00n)
i still cant figure this out...HELP
Old Apr 10, 2006 | 06:05 AM
Mag00n's Avatar
theres also a blue/black and yellow/black wire plug that plugs into some sort of solenoid under the glove box but it doesnt look like a service connector...
Old Apr 10, 2006 | 09:24 AM
Mag00n's Avatar
Old Apr 10, 2006 | 10:55 AM
ChicagoMike's Avatar
If ya hang on I'll get some pics up.....
Old Apr 10, 2006 | 10:58 AM
Mag00n's Avatar
Default Re: (AddictiveAllMotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AddictiveAllMotor &raquo;</TD></TR><TR><TD CLASS="quote">If ya hang on I'll get some pics up.....</TD></TR></TABLE>
Old Apr 10, 2006 | 11:00 AM
Default Re: (Macan00n)
Check your harness and look for this plug.
Old Apr 10, 2006 | 11:19 AM
Mag00n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AddictiveAllMotor &raquo;</TD></TR><TR><TD CLASS="quote">Check your harness and look for this plug.
theres nothing like that
this is not a stock car its an 85 crx si.
there are 4 wires out of the ecu that are tapped off and tapped together
blue/white and solid gray
blue/white and brown/white
in the engine bay near the intake manifold there is a 2 wire plug that is unused. the wires going into are red and yellow
Old Apr 10, 2006 | 11:23 AM
OK, I'll do some searching around and see what I come up with.
Old Apr 10, 2006 | 11:25 AM
Mag00n's Avatar
i appreciate the help this is like the bastard child of vtec ecu's
or maybe its just the car its in
Old Apr 10, 2006 | 12:41 PM
Mag00n's Avatar
ok i figured out the pin is D4 the wire is brown/white so do i need to ground it or feed it volts to make it flash the code?
Old Apr 10, 2006 | 01:13 PM
Mag00n's Avatar
i got it guys.
its pin D4 and you ground it to flash the codes, in case anyone sees this in archives
tekstyle
Feb 27, 2008 12:15 PM
yeahright
Sep 13, 2006 04:55 PM
thatbluecrx
Jun 4, 2005 10:32 AM
crx90rcr
Jan 6, 2005 12:48 PM
LshatchTurbo
Oct 13, 2001 05:16 PM
