ECU hondata 0r crome?
Old Mar 19, 2006 | 06:07 AM
jdmeg9's Avatar
Default ECU hondata 0r crome?
what setup is everyone running? which is better or is there one?
Old Mar 19, 2006 | 06:26 AM
Padawan's Avatar
Darth ModerVader
Default Re: ECU hondata 0r crome? (jdmeg9)
I think the clear advantage that something such as Uberdata or Crome has over Hondata is the fact that it is virtually free (depending upon your ECU) yet still offers a tremendous amount of tuning ability as well as the option to do your own tuning if you have the knowledge to do so. As such, it is almost always what I suggest to individuals.
Old Mar 19, 2006 | 06:54 AM
jdmeg9's Avatar
Default Re: ECU hondata 0r crome? (Padawan)
but with Uberdata and Crome you have to take the chip out and reflash correct? with the hondata s300 you never have to open the ecu again right?
Old Mar 19, 2006 | 06:59 AM
hondachris1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">but with Uberdata and Crome you have to take the chip out and reflash correct? with the hondata s300 you never have to open the ecu again right?</TD></TR></TABLE>Wrong my chipped p28 has uberdata/chrome hookup on the side its a 4 pin connector on the side of the ecu
Old Mar 19, 2006 | 07:00 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ECU hondata 0r crome? (hondachris1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">Wrong my chipped p28 has uberdata/chrome hookup on the side its a 4 pin connector on the side of the ecu</TD></TR></TABLE>
Isn't that for datalogging only?
Old Mar 19, 2006 | 07:02 AM
jdmeg9's Avatar
I'm just trying to get my feet in the water i am wanting to learn how to do this for myself so i don't have to depend on anybody
Old Mar 19, 2006 | 07:09 AM
gunnis's Avatar
"Better" is totally subjective.
Crome, Uberdata, Neptune definitly are a cheaper alternative to say Hondata. Not neccesarily better.
All these offer very similar options in the way of tuning capabilities, some may do a certain thing "better", but they are afterall out to accomplish the same goal.
Some chips do not need reflashing, and you can simply just reburn. Yes, you will need to remove it, to place it on a chip burner. Some will need reflashing everytime.
My suggestion would be unless your planning to full out learn and tune your car yourself, go with what the tuner in your area uses and knows best. Theres no sense is having (insert hondata,crome,neptune,uberdata here) if you or anybody your taking the car to, knows jack about it.
If you know nothing about it (like myself). Check out http://www.pgmfi.org, it owns.
&lt;-----Running chipped p28, using crome. hopefully a dyno tune in another month.
Old Mar 19, 2006 | 09:20 AM
SOHC_MShue's Avatar
Most people tuning Crome and Uberdata use an ostrich which hooks up to the laptop via usb and can be reflashed on the fly basically just like s300.
Old Mar 19, 2006 | 11:37 AM
Dartanian's Avatar
Default Re: ECU hondata 0r crome? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
Most people tuning Crome and Uberdata use an ostrich which hooks up to the laptop via usb and can be reflashed on the fly basically just like s300. </TD></TR></TABLE>
I have the ostrich and it offers the same RTP as the Hondata S300 does. My ECU stays in the stock location and my Ostrich sits in the glovebox, so whenever I need to change something, I just have to plug my Ostrich into my computer and upload changes.
Hondata and Crome are really very similar and can do most of the same things, but with Hondata, you are paying for the convenience of having all the hardware and software working correctly right out of the box.
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
thewrai6th
Oct 9, 2007 09:38 PM
jdmredgsr
Mar 30, 2007 05:12 PM
inh
Apr 19, 2006 08:30 AM
Sohc Driver
Nov 18, 2003 10:18 AM
