92 Accord Ex.....REAR wheel bearing, Disk Brakes,ABS, Need help
Well my Honda Service Manual finally came in, but it doesn't say much on changing a rear wheel Hub Bearing with Disk Brakes...It just says and shows for Drum brakes....Are the procedures the same....?
What do they mean when they say "stake the spindle nut shoulder against the spindle"...?
Is there a special hub with a sensor i need to replace mine if my veichle is equiped with ABS, or is this just for the front wheel bearings..
Anything i should keep in mind before attempting to do this, Do i need to grease anything, lube anything....
This is my first time looking at these Honda service manuals, the spindle nut is supposively 22X1.5 mm and torqued to 134 lb-ft, so does this mean i need a 22 MM socket to remove and tighten this spindle nut, i'm lost here...Please help.
go to http://www.ozaccord.com ask the questions to deserthonda
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPINSI »</TD></TR><TR><TD CLASS="quote">Anyone....amckee or BLKFLSH, you guys chime in, please...Thanks.</TD></TR></TABLE>
read my previous post ............
did you go there and ask ???
Not exactly sure what your asking.. are you wanting to know how to change the wheel bearing, or wanting to know if theres a sensor, what specifically are you wanting to know?
There isn't any special sensor. The replacement of the rotor and hub takes less than 15min if you have all the tools.
I was just wanting to know if it is the same to change the rear wheel bearing if you have disk brakes as opposed to drum brakes, My Honda service manual tells how but ONLY shows drawings on how to do drum brakes....
I also wanted to know if the service manual says the bolt (any bolt) is a certain size, is that the size wrench i'll need to remove and or tighten that particular nut...? Do i make sense..?
Honda-Master...No, i did not ask on the link you gave me, i have had really good luck on Honda-Tech, amckee and BLKFLSH had helped me a bunch, i was just trying to get their opinions....I was not ignoring your suggestion, just wanted to get feedback from these members, sorry if you felt other wise....
Honda-Master...No, i did not ask on the link you gave me, i have had really good luck on Honda-Tech, amckee and BLKFLSH had helped me a bunch, i was just trying to get their opinions....I was not ignoring your suggestion, just wanted to get feedback from these members, sorry if you felt other wise.... </TD></TR></TABLE>
It is ok.
.i was just giving you another avenue to get an answer ..I respect the fact that you are loyal to this site and that you respect the opinions of Amkee and Blkflsh....they are knowledgable people ......while you are at it , ask them about Deserthonda ...
It is ok.
.i was just giving you another avenue to get an answer ..I respect the fact that you are loyal to this site and that you respect the opinions of Amkee and Blkflsh....they are knowledgable people ......while you are at it , ask them about Deserthonda ...Thread
vigorhy
Jun 10, 2008 05:25 PM
