S2000 taillight swap????
Quick question.... Will the 05-06 led taillights directly bolt in to 00-04? I've researched and cant find anything on it......I'm pretty sure they will, just checking before I make the purchase....
Thanx
Thanx
I did this. It took around 2 hours to do becaus we had to dremel out a larger hole for the new housings. You'll also have to make sure you make a metal bracket to hold the inside part of the housing or your gasket will be exposed and condensation will occur. Dremeling down the sockets to fit the new ones was a pain. The turn signal bulbs also needs to get adjusted so that they don't hyper blink.
The brake light is the LED unit itself. It's a lot cheaper shaving down the original sockets. It's very easy to understand once you attempt to plug in the sockets once 2004+ taillight is installed. That is the hard part. Overall, become and s2ki user and here is the whole conversion step by step http://www.s2ki.com/forums/ind...83447
