If anyone can help
I just put a diffrent motor in my teg(stock ls) when I give it gas is seems to not have any torque.U can here the are going through the tb but the car doesnt pull.Also the idle is a litrle high(1100 at stand still) and it will bounce every once in a while from 1100-1300rpm.When I let off the gas the idle will drop low then bounce back up.Any ideas?
write in english and spell words correctly.... took me a min to realize you mean you could HEAR the AIR going through the Throttle Body... how did you hear that and differentiate it from air anywhere else BTW. Anywya we need more detail, when is it doing this stupid idleing? What temp is your car at?
I just put a diffrent motor in my teg(stock ls) when I give it gas is seems to not have any torque.U can Hear the air going through the intake/Throttle body but the car doesnt pull.Also the idle is a litrle high(1100 at stand still) and it will bounce every once in a while from 1100-1300rpm.When I let off the gas the idle will drop low then bounce back up.Any ideas? Car is at normal temprature when the motor does this and when I first start it the motor idles at 2,000 rpm
DeLSoLRo
20
Apr 23, 2011 10:06 AM
ONE-CAM-EF
10
Jan 20, 2008 12:31 PM
