95 acura LS
hi i'm leaving the car parked with no insurance.. what fuses can i pull out to insure my **** don't get bagged.. what do u recommend i do.. the car is a 95 acura integra LS its a 5spd.. disconnecting the battery is pointless because they can bypass that and the starting by doing a rolling start.. thanks..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped »</TD></TR><TR><TD CLASS="quote">hi i'm leaving the car parked with no insurance.. what fuses can i pull out to insure my **** don't get bagged.. what do u recommend i do.. the car is a 95 acura integra LS its a 5spd.. disconnecting the battery is pointless because they can bypass that and the starting by doing a rolling start.. thanks..</TD></TR></TABLE>
im pretty sure they wont be able to start your car with out the battery(not positive). my batterys beed so dead before that i couldnt even push start it. plus they can just bring their own battery. not to mention if they did get it started it would fry you alternator in a matter of minutes
if its gonna be sitting there for long, i would pull the fuel pump or just disconnect it. and i would put the car up on jackstands take the wheels inside
Take the battery out, along with ecu, put a club stick in it, alarm in it, take all the fancy **** inside out, put black paper over the windows ( if u dont have them tinted) so that at night they cant look inside... IDK think bro
hope this helped !
hope this helped !
ecu is in the kick panel on the passenger side. (in the outside corner), and no it wont give you a check engine light. it will just reset, just like if you unplug your battery
