02 RSX Headlight Replacement
Old Mar 18, 2006 | 07:39 PM
mr devious illusions's Avatar
Default 02 RSX Headlight Replacement
ok... ive changed bulbs once... and that was by removing the bumper. i was wondering if theres an even easier way of doing it. id do it by just opening the hood and just change bulbs the ordinary way.. but shiet... it soo fukkn crampt in there. so i figure.. take off bumper. yeah it was easier to change that way.. but takes too long to take off bumper and what not.
so yeh.. anyone has suggestions on doing it a lil quicker than that?
Old Mar 19, 2006 | 03:46 PM
Default Re: 02 RSX Headlight Replacement (magikalxpinoy)
ttt
Old Mar 19, 2006 | 04:56 PM
NBPcivic07's Avatar
well u can disassemble the fuse box on one side and the other the fluid tube comes out well unhook
Old Mar 20, 2006 | 07:14 AM
Jammer's Avatar
Default Re: 02 RSX Headlight Replacement (rsxtypes03)
I've gotten cheap bulbs that blew like every other week. The first time I put them in took a little while but the more and more you do it the gasket gets esier to remove and it goes by quicker. Also, the washer fluid openning can move and so can the tank o the other side.
I just got new better bulbs so hopefully I don't have to do it for a while.
Old Mar 20, 2006 | 07:51 AM
Supa Lao's Avatar
I've heard some people do it by just sticking there hands in there.
I find it a lot easier to just take off the front bumper.
Old Mar 21, 2006 | 11:18 PM
turbostu's Avatar
Default Re: (Supa Lao)
taking off front bumper is easiest.look at it this way, it will only get faster as u do it more and more.
Old Mar 22, 2006 | 08:07 PM
Ocelaris's Avatar
One tip of advice, don't buy aftermarket bulbs that are blue or "high wattage" they last a very short time because they have to work harder to produce even the same amount of light. The only bulb worth buying which is not an OEM bulb is the Toshiba Infra-Red bulb which puts out almost 2x the amout of light as ordinary bulbs with the same life span. rallylights.com is the only place I know that carries them.
God kills a kitten everytime you put blue bulbs in your ricemobile.
Old Mar 22, 2006 | 11:51 PM
ProJectCvic's Avatar
Default Re: (Ocelaris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ocelaris &raquo;</TD></TR><TR><TD CLASS="quote">One tip of advice, don't buy aftermarket bulbs that are blue or "high wattage" they last a very short time because they have to work harder to produce even the same amount of light. The only bulb worth buying which is not an OEM bulb is the Toshiba Infra-Red bulb which puts out almost 2x the amout of light as ordinary bulbs with the same life span. rallylights.com is the only place I know that carries them.
Link us to this . I can't seem to find it.
Old Mar 23, 2006 | 12:49 AM
when it comes to higher wattage bulbs.. what my friend told me, is that APC actually makes upgraded wire harnesses. and that actually does work.
APC finally has something useful. i found a set at Pep Boys.
Old Mar 23, 2006 | 04:51 AM
StupidSlowRSX's Avatar
Default Re: (magikalxpinoy)
umm
lol
I have an 03 Type S and I went thourgh a stage where I was blowing blubs a lot. You don't need to take the front bumper off.. All I do is move the washer fluid resivor and move the power steering fluid resivior. I takes me a total of 5 minutes to change the low beams and 5 minutes for the brights. Its really easy, I can't believe you were actually taking the front bumper off...
hahahahah
noobie.
IgnitionZ05
11
Oct 16, 2006 07:21 AM
BoBoChan
Oct 18, 2005 07:15 PM
firstacura
Aug 13, 2004 08:17 PM
succdeez
Jun 9, 2003 09:27 PM
kliq
Jun 5, 2003 07:03 PM
