Steering wheel wiggles, car shakes
Old Mar 18, 2006 | 05:57 PM
tom_zeke's Avatar
Default Steering wheel wiggles, car shakes
Hey guys. First of all, I searched the archives and couldn't find a thread that fit my specific issues. I have a 99 Civic LX. At low speeds, my steering wheel wiggles, and the car itself shakes laterally. It doesn't quite swerve from side to side, but there is definitely a back and forth motion that is very perceptible at lower speeds (5-15 mph). I read several threads about loose steering wheels, shaking steering wheels, and other vibrational issues, but none of those dealt with the car actually "wiggling" laterally. I'm not sure whether the problem lies with unbalanced tires, an unaligned front end, damaged tie rod ends, or something else. Any help would be appreciated.
Old Mar 18, 2006 | 06:23 PM
k0rean4life's Avatar
Default Re: Steering wheel wiggles, car shakes (tom_zeke)
Could be any thing really until you get the time to look at it. Could be bad aligment or if ur car is slammed bad chamber can expletive ur tires up. Just hope its not wheel bearings cause those are annoying to replace?
Did you hit a curb at any time before it started this?
Old Mar 18, 2006 | 06:33 PM
tom_zeke's Avatar
Default Re: Steering wheel wiggles, car shakes (k0rean4life)
Nope. I didn't hit anything that would've caused this to happen. I've been teaching my wife how to drive a standard on my civic, and she admitted to being a little rough on it when driving to pick my drunk *** up from a UFC party, but I don't know if her putting my transmission through hell would've messed up the steering.
Old Mar 18, 2006 | 06:34 PM
hi-Powered's Avatar
replace your drive axles.
Old Mar 18, 2006 | 06:37 PM
Default Re: Steering wheel wiggles, car shakes (hi-Powered)
Yeah you really need to look at it. If its the axels roll ur window down and try to listen if theres a clicking sound if so ur axels could be bad, also jack the car up and look to see the axels might have a broke CV joint, they will be execess grease on the boot or around it.
Old Mar 19, 2006 | 11:25 AM
tom_zeke's Avatar
The CV joints look fine. I took some photos, but I'm not sure how to post them. But I couldn't see any grease on or around the boots.
Old Mar 19, 2006 | 12:06 PM
Farmer Brown's Avatar
How new/used are your tires? You might have a bad tire or two. As in the tread is separating, which can happen even if you seem to have plenty of tread left.
Simplest way to check is simply slap the spare on one side at a time and see if that fixes anything.
Old Mar 19, 2006 | 12:11 PM
tom_zeke's Avatar
Default Re: Steering wheel wiggles, car shakes (Djaric)
Gotcha. A buddy of mine is storing a spare set of '95 Del Sol tires in my basement. I'll give those a try and see if it fixes the problem.
Old Mar 19, 2006 | 12:24 PM
REAL TIME's Avatar
are your tires balanced? Some shops are too shady to take time balance a wheel.
Modified by Spoon_Fed_EM1 at 2:01 PM 3/19/2006
Old Mar 19, 2006 | 12:38 PM
erasable180's Avatar
a balance issue is normally prominent at speeds higher than 5-15mph. i would look at front end components- ball joints, inner and outer tie rods or a bent wheel.
Old Mar 19, 2006 | 03:02 PM
tom_zeke's Avatar
Default Re: (erasable180)
Djaric nailed it. I swapped the tires out with tires off a '94 Del Sol (not a '95, as posted earlier).
Old Mar 19, 2006 | 03:09 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
maybe a bubble in one of the tires?
Old Mar 19, 2006 | 03:17 PM
KoLRaNcH's Avatar
Default Re: (tom_zeke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tom_zeke &raquo;</TD></TR><TR><TD CLASS="quote">Djaric nailed it. I swapped the tires out with tires off a '94 Del Sol (not a '95, as posted earlier). </TD></TR></TABLE>
Was there a lot of wear on the inside of the tire?
Old Mar 19, 2006 | 06:47 PM
tom_zeke's Avatar
Default Re: (KoLRaNcH)
Nope. The tires are pretty old, though.
Old Mar 20, 2006 | 08:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tom_zeke &raquo;</TD></TR><TR><TD CLASS="quote">Nope. The tires are pretty old, though.</TD></TR></TABLE>
My girlfriends car recently did this, and Ive had it happen before. Its the weirdest feeling. lol
ribal_gh
Honda Civic (2006 - 2015)
Mar 31, 2015 10:47 PM
Papalou
Jan 19, 2014 10:40 AM
DawgC2
Suspension & Brakes
12
Dec 11, 2011 05:01 PM
lildragon'07
13
Jun 2, 2010 08:31 AM
JoKarma
Sep 20, 2005 10:56 AM
