Drainging coolant question!!!! IS THIS POSSIBLE???
Old Mar 18, 2006 | 05:11 PM
DeDonDeRosa's Avatar
Default Drainging coolant question!!!! IS THIS POSSIBLE???
ok a friend of mine has told me that it is ok to drain the coolant out of a car while its still hot. i told him that i dont think that it would be good for the car. what do u think???
IS IT OK TO DRAIN HOT COOLANT OUT OF A CAR WITHOUT HURTING THE MOTOR. (im talking like driving the car for an hr shutting it down waiting 10-15 min the draining to coolant)
Old Mar 18, 2006 | 05:28 PM
super_mut's Avatar
Default Re: Drainging coolant question!!!! IS THIS POSSIBLE??? (DeDonDeRosa)
Wow, thats a horrible idea.
First off its EXTREMELY UNSAFE. You can burn yourself horribly enough to be taken to the ER with hot coolant. Plus its under pressure, the radiator.
JUST BE PATIENT AND WAIT FOR IT TO COOL DOWN.
Old Mar 18, 2006 | 05:29 PM
mike9571's Avatar
I dont see how it would affect anything but maybe im wrong. HA the only reason u shouldnt do it is becuause obviously you can burn the crap out of yourslef.
Old Mar 18, 2006 | 06:14 PM
Sam92Teg's Avatar
Default Re: Drainging coolant question!!!! IS THIS POSSIBLE??? (mike9571)
The bigger concern is not to add cold water to a hot block.
Old Mar 18, 2006 | 06:25 PM
OH_SNAP10k_SHIFT!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">ok a friend of mine has told me that it is ok to drain the coolant out of a car while its still hot. i told him that i dont think that it would be good for the car. what do u think???
IS IT OK TO DRAIN HOT COOLANT OUT OF A CAR WITHOUT HURTING THE MOTOR. (im talking like driving the car for an hr shutting it down waiting 10-15 min the draining to coolant)</TD></TR></TABLE>
its perfectly ok. i do it all the time at the dealership. i mean it sucks for the techs working on the car coz its hot. u just gotta be real careful when u open the radiator cap. and as for the engine, nothing bad is gonna happen to it.
Old Mar 21, 2006 | 07:46 AM
vtecman's Avatar
JUST DO WHAT YOUR BROTHER TELLS YOU TO DO DAMIT!!!!!!!
Old Mar 21, 2006 | 07:52 AM
Uncle Willie's Avatar
Default Re: Drainging coolant question!!!! IS THIS POSSIBLE??? (OH_SNAP10k_SHIFT!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH_SNAP10k_SHIFT! &raquo;</TD></TR><TR><TD CLASS="quote">
its perfectly ok. i do it all the time at the dealership. i mean it sucks for the techs working on the car coz its hot. u just gotta be real careful when u open the radiator cap. and as for the engine, nothing bad is gonna happen to it.</TD></TR></TABLE>
Yup, but at the dealer, you probably have a machine like i have at a quick lube place. So you wont be draining the block, and then adding cold water, which may or may not crack the block. I dont know because i have rinsed down toyotas before doing an oil change when they are hot as hell and ive never cracked a block yet.
Its better to be safe than sorry. Just wait 25-35 min and it will be fine to work on w/o getting burned
Old Mar 21, 2006 | 09:24 AM
IVI's Avatar
IVI
Default Re: Drainging coolant question!!!! IS THIS POSSIBLE??? (RIP Indian Larry)
i would do the coolant when cold. i would do the oil when hot. the coolant is thin, also your flushing it most likely not just draining it like oil.
so its going to get everything out regardless.
do it when cold.
Old Mar 21, 2006 | 09:30 AM
Tornadom's Avatar
For the sake of safety wait until the coolant temperature has gone down a little bit.
Old Mar 21, 2006 | 10:37 AM
TRE_'s Avatar
Default Re: Drainging coolant question!!!! IS THIS POSSIBLE??? (Tornadom)
Makes no difference wether its hot or cold, just make sure you dont burn yourself.
ricerollz
Sep 22, 2010 10:05 AM
Jonovision
Honda Civic (2006 - 2015)
Jan 15, 2007 11:04 AM
tallyBanned
Aug 18, 2006 08:50 AM
DelSlowdier
Jan 16, 2005 08:42 PM
94gsr18kid
Dec 29, 2004 08:12 AM
