Seats in EK9 PLEASE HELP!!!
Hey fellas, I am lookin to get leather seats in my EK9. I have looked at a few like the gsr's and the rsx's
Anyone have any experience these?
I need to know how they fit, and are their any modifications involved in getting it to fit. what about fitment? any gaps?
Please help me out, and pictures would help.
*i wanted to go with the JDM recaros but they would get dirty....
I just wanted to clear up a couple things for you. Integra GSR seats will bolt right up IF you used your stock Civic seat brackets. If you keep the stock GSR brackets (Like I did, because they sit lower to the floor than Civic brackets do) You will have to modify the brackets. 3 out of the four bolts will line up, but the back inside bolt points do not. It is easy to modify them by just cutting a tab and using a large washer to hold it down.
Anyways, I hope this helps you out!
RSX seats look fugly in an EK - they're too damn big & wide and look out of place in an EK interior. That and the fact that you'll have to fab all custom rails just to get the front seats in and the back seats don't go in easily at all (there are gaps if you don't add some padding, etc.). All DC2 Integra seats will bolt in perfectly so long as you have both rails from the DC2 as well as your stock EK rails.
Alright i still have my stocks in there so using those brackets will be no prob at all.... so if i do use the stock's brakets they will sit with no problem, everything lines up and bolts in, and what about the gaps?
thanks! and bump for help
Here was the DIY I followed when I put my ITR seats in my '99 SiR:
http://www.geocities.com/motor....html
yeah i saw EK9 in the title and i was like daaang looks like i'll get a glimpse of a real CTR which i haven't seen in a while.......but go figure...someone with there EJ hoping and praying its an EK9...w/e i have JDM recaro's and there never dirty...
just get the Gsr's....bolt em in...be happy...and have fun with your "EJ"...
i had 99 GSR front and back leather seats... they were coo, just for the two front seats, one bolt will not be bolted down cuz i used the stock brackets, and the back seats need to be customed fitted kinda hard, i used a metal rod to put in between the holes so the seats (upper rear) wouldnt move...
wunfstgsr
Welding / Fabrication
Mar 21, 2009 06:20 PM
