PLEASE HELP ME ON MY NEW INTAKE SYSTEM
Old Mar 18, 2006 | 03:24 PM
Dr. Phil's Avatar
Default PLEASE HELP ME ON MY NEW INTAKE SYSTEM
Today I went to discount auto parts and baught a apc intake system for my 94 ex. I took out the stock system and put on the new one. Looks nice but it does not run right. It idles low, and when I turn it on, it sounds like its going to turn off. But it doesn't. Now, on the old factory intake system there were two hoses that went on the intake system. One came from the valve cover to the intake system and the other came from somewhere else that also went to the intake system. I removed the old system and put the new on. I put the new hose that went from the valve cover to the intake system and the other hose........ well there was not a spot for that. What do I do with that hose???? Also the instruction told me to drill a hole on the rubber part on the back of the air filter so that I can put the vacum hose through it. I did that. I hope I didn't screw up on the vacum hose. I believe I put the right one in.
Does anyone have step be step pic on how to install the system??? I tried googling for a 1/2 hour and I found nothing. I also tried searching for this on here. I found nothing as well. So now I come to you guys for help.
Old Mar 18, 2006 | 03:31 PM
P_Adams's Avatar
Default Re: PLEASE HELP ME ON MY NEW INTAKE SYSTEM (Dr. Phil)
Grab your Sales slip and give me the APC Part number of the unit you bought. I'll see if I can scare up something for you.
I can't see where there should be any reason for a reaction like that... perhaps something will hit upside the head
P
Old Mar 18, 2006 | 03:44 PM
Dr. Phil's Avatar
Default Re: PLEASE HELP ME ON MY NEW INTAKE SYSTEM (P_Adams)
thanks adam its 151004k
Old Mar 18, 2006 | 03:46 PM
P_Adams's Avatar
Hello Webferret, Here I come (wish me luck)
APC 151004(k) correct?
P
now why did I do that??
Modified by P_Adams at 1:09 AM 3/19/2006
Old Mar 18, 2006 | 03:48 PM
Dr. Phil's Avatar
thats what it said on my receipt
Old Mar 18, 2006 | 03:54 PM
P_Adams's Avatar
So, you went with the APC Intimidator did ya?
Old Mar 18, 2006 | 03:57 PM
Dr. Phil's Avatar
yes sir or
Old Mar 18, 2006 | 04:06 PM
P_Adams's Avatar
The 151004(k) comes up for the APC 151004K Air Intake Int. Intake Accord 94-97 - 94-97 Honda Accord Except Dx, With Filter, Polished EXCEPT V6 engine
P Still looking (found some for a 003K (But)
Old Mar 18, 2006 | 04:13 PM
Dr. Phil's Avatar
So I got the wrong one.........?
Old Mar 18, 2006 | 04:21 PM
P_Adams's Avatar
Nope, the 004k is correct (I went Dyslectic ) sorry
P
Old Mar 18, 2006 | 04:25 PM
Dr. Phil's Avatar
So what do I do with that extra hose????? I think I lost power on my top end.
When I take off it gets to 3 1/2 rpm kinda fast then it looks like it slows down after that. Do you have a pic of my motor that you can put up and I'll show you what hose I'm talking about. And thank you adam for helping me on this
Old Mar 18, 2006 | 04:52 PM
P_Adams's Avatar
I haven't forgotten you, I just gotta put this down for a minute. I've looked at about 30+ web sites so far and I'm finding everything but....
Let me have a coffee and I'll take another whack at it.
P
Old Mar 18, 2006 | 05:36 PM
P_Adams's Avatar
Larger of the two (most likely the one supplied) goes to the Valve Cover breather assembly. The other one went to the area of the Throttle Body.
The problem I'm running into is I can find the instructions for the 151003k Kit, but not the 151004k Kit. So, as far as the small one....
If your vacuum hose map is still intact under the hood, you might be able to interpret it..
P
Old Mar 18, 2006 | 05:54 PM
Dr. Phil's Avatar
I found the problem. I did not plug a sensor back in its place. It was the sensor that went on top of the throttle body. It runs like a champ. I love the sound she makes at 4500 rpm. Thanks adam for everything. I wish I could make madonna give you a blow job for you trying to help me. once again, thank you adam
Old Mar 18, 2006 | 08:12 PM
P_Adams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. Phil &raquo;</TD></TR><TR><TD CLASS="quote">Thanks adam for everything. I wish I could make Madonna give you a blow job for you trying to help me. once again, thank you adam</TD></TR></TABLE>
I'm on my way to London, call ahead
(That was the MAP Sensor (Manifold Absolute Pressure)(by the way)
P
spell checker lied
Modified by P_Adams at 5:47 AM 3/19/2006
rbizzell30
Jun 13, 2008 03:06 PM
mugenspoongsr
Jul 1, 2005 08:35 PM
jnet
Nov 2, 2004 07:11 PM
Tad
Nov 1, 2004 12:06 PM
