Can I install the oem body kits myself?
Old Apr 1, 2002 | 09:54 PM
nEoMuGen's Avatar
Default Can I install the oem body kits myself?
The rear and sides are for myself. The front is for my friend's car.
I see some pre-drilled holes on the rear bumper for mud guards...I just wonder if I can install these kits with just a screw driver without drilling any holes.
And how do I prevent people from stealing the kits? If they are easy to put on, they should be easy to be taken off as well.
Old Apr 1, 2002 | 09:58 PM
Bob#455's Avatar
Default Re: Can I install the oem body kits myself? (nEoMuGen)
Yes, you can install them yourself...yes, you need to drill a couple of holes to install the rear pieces. As far as preventing theft of your kit, just cross your fingers...
Old Apr 1, 2002 | 10:40 PM
B00ST2nR's Avatar
Default Re: Can I install the oem body kits myself? (Bob#455)
took me an hour tops installing the whole kit. The front and sides are easy as hell. The rear is a bit tricky. You drill holes. There's this little metal thingy you have to get in (You'll see what i'm talkin about), but after that, its all good.
Try to get a friend to help you hold stuff, etc. It goes alot smoother and faster. Plus its less boring.
Old Apr 2, 2002 | 08:48 PM
nEoMuGen's Avatar
Default Re: Can I install the oem body kits myself? (GS-R)
Oh, and do I just rip off the oem painted side bumper piece?
Old Apr 2, 2002 | 08:49 PM
JL 74's Avatar
yes, it is easy
Old Apr 2, 2002 | 08:53 PM
JL 74's Avatar
Default Re: Can I install the oem body kits myself? (jl74)
yes, it is easy
I am not going to exaggerate on time, it took me nearly half a day (3-4 hours) to do it right, especially the front when I was attempting to remove the bumper, ALSO, washing the car and waxing the pieces that will be covered.
Old Apr 2, 2002 | 08:58 PM
Bob#455's Avatar
No, don't "rip" it off. You need the hardware for the sideskirts you're going to install... Undo the screws, and slide it off.
Old Apr 2, 2002 | 09:15 PM
nEoMuGen's Avatar
Thanx guys
vegas36
Aug 2, 2004 04:36 PM
boost fed ls
May 3, 2004 05:36 PM
UnionCity LS
Mar 5, 2004 07:41 PM
JadeDM
Sep 22, 2003 02:16 PM
yellowbuffalo
Jun 13, 2002 06:45 AM
