Suspension & Brakes Theory, alignment, spring rates....
Sway Bar Bolts..
Old Mar 18, 2006 | 11:34 AM
Ls_TurboEG's Avatar
Default Sway Bar Bolts..
What size are the sway bar bolts for the JDM ITR 23mm sway? I'm putting it with the Omni's and I'm wondering what size the bolt is, and where i should pick it up.. I was thinking Honda OR try and eyeball it @ Home Depot, but i'd rather have the specific bolt. Help would be appreciated. Thanks Guys..
Old Mar 18, 2006 | 12:37 PM
743power's Avatar
Default Re: Sway Bar Bolts.. (Ls_TurboEG)
what bolts? end link to sway? end link to lca? sway bracket to subframe? Get them from honda, they are some of the cheapest honda bolts you can buy.
Old Mar 18, 2006 | 03:18 PM
Ls_TurboEG's Avatar
Default Re: Sway Bar Bolts.. (743power)
Sorry.. to specify they're endlink to LCA, was curious, these endlinks will work correctly with the OMNI Lca's right? just wanting to verify, im a newb to swaybars. here's a pic of them. Also, when i go into to honda should i ask for the ITR sway bar bolts or will the civic ones be the same size? Thanks, any help is appreciated.
Old Mar 19, 2006 | 01:49 AM
hazard_one's Avatar
i believe its M10 1.25 X 45mm or equivalent since your lcas arnt threaded
Old Mar 19, 2006 | 06:37 AM
743power's Avatar
Default Re: Sway Bar Bolts.. (hazard_one)
use honda bolts. i just got some itr sway endlink bolts for like $.46 each at the dealer. I used the nicest metric bolts i could find at ace hardware before with a 14mm rear sway, and they actually bent like a ***** and almost ripped out the threads on the LCA. With that sway (looks like a 22mm), you need somtething equivalent to what honda uses.
Old Mar 19, 2006 | 04:55 PM
hayabusa160's Avatar
because i had the a spec racing brace the oem lca bolt was nto needed no more so i used those for that part of the end link
with the after market lca you have to use some washers on it so the end link is parallel with the lca.
Old Mar 20, 2006 | 04:36 PM
Ls_TurboEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazard_one &raquo;</TD></TR><TR><TD CLASS="quote">i believe its M10 1.25 X 45mm or equivalent since your lcas arnt threaded</TD></TR></TABLE>
so what ur saying is that the ITR LCA is threaded?
Old Mar 20, 2006 | 05:42 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_TurboEG &raquo;</TD></TR><TR><TD CLASS="quote">
so what ur saying is that the ITR LCA is threaded?</TD></TR></TABLE>
all hond lca's for rear sway are threaded. he said the omni lca's aren't threaded (i dont know if they are or not), so you will need a longer bolt to go through the arm and use a nut on the other side.
Old Mar 20, 2006 | 06:56 PM
Ls_TurboEG's Avatar
So the integra type R ones i got from honda wont work then bcuz they're too short? or will the Omni LCA's lack of thickness make it so that it works!
Old Feb 10, 2007 | 07:30 PM
vtecndarkie's Avatar
Default Re: (Ls_TurboEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_TurboEG &raquo;</TD></TR><TR><TD CLASS="quote">So the integra type R ones i got from honda wont work then bcuz they're too short? or will the Omni LCA's lack of thickness make it so that it works!</TD></TR></TABLE>
I need this same question answered.
nghtshd88
Mar 4, 2012 02:32 PM
fergs96integra
Jul 21, 2010 07:07 PM
s1ngle
Dec 4, 2007 07:43 PM
RevedOut
Feb 12, 2002 01:36 PM
