some stuff i've been fabbing
this is for someone's d-series setup that i did.
hf-garrett t25/t28 adapter:
had to add a bracket to relocate the wg:
also had to shorten the activator arm:
had to backdoor his ic to keep ps:
added some mounts for the ic:
one coupler from turbo to ic:
he wanted to use his aem cai, so i just made this one to connect from the ic:
added the bov afterward so it wouldn't affect his aem pipe:
and his 2.5" dp, as comparison to my 3" that has yet to get the dump tube put into it:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermal »</TD></TR><TR><TD CLASS="quote">Weir, nice job man. ....as usual</TD></TR></TABLE>
definetly!
definetly!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech »</TD></TR><TR><TD CLASS="quote">this is for someone's d-series setup that i did.
c047000ep.jpg[/img][/url]</TD></TR></TABLE>
Yikes... isn't it bad to have the actuator arm at a gnarly angle like that?
A friend of mine's DSM had a tweaked turbo (compressor was somehow clocked causing the arm to bind up like that) boost response was wierd; never linear and it spiked bad. Not knowing any better we swapped out the turbo and found out later that was the problem. turbo is now on another car running fine.
jason DB8
Sep 3, 2006 11:43 AM
jason DB8
Jul 24, 2006 12:01 PM
