possible bent valve?
Old Mar 18, 2006 | 09:26 AM
Linh.'s Avatar
Default possible bent valve?
I went to the track a couple weeks back and the car ran find didn't misshift/over rev at all. Three days later I was comming home from work and started to hear a tick noise. Came home and thought nothing of it woke up next day I didn't hear anything. Now its back and its ticking pretty loud and only ticks at around 3k rpm. I just adjusted the valves and three off them on the intake side were a bit off. Also checked for compression and they read find nothing looked wrong. Can anyone give me some symptons of a bent valve? I need to do a leak down test but dont have one does autozone rent them out?
Old Mar 18, 2006 | 11:40 AM
951dc5's Avatar
Default Re: possible bent valve? (shooitslinh)
your rods are knocking waiting to be shot
Old Mar 18, 2006 | 11:48 AM
Linh.'s Avatar
Default Re: possible bent valve? (Prelude951)
i did a compression test and it look fine to me 250 on all four
Old Mar 20, 2006 | 08:04 AM
Linh.'s Avatar
bump for some more info.. Checked my spark plugs and the white part of the spark plug is turning black...
Old Mar 20, 2006 | 10:37 AM
JDMF22B's Avatar
well its my understanding that if your spark plugs were indeed going bad, youd be lacking compression. But, I could be wrong.
Does it drop revs, stall, bog, anything? Just a tick? I mistook my rod knock/prefiring for a tick too. 2 Day later, bam boom rod gone
Old Mar 20, 2006 | 12:29 PM
limpmode's Avatar
Default Re: possible bent valve? (JDMF22B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMF22B &raquo;</TD></TR><TR><TD CLASS="quote">well its my understanding that if your spark plugs were indeed going bad, youd be lacking compression. But, I could be wrong.</TD></TR></TABLE>
as long as the plugs are there, you will have compression. unless one is pretty loose.
edit: unless the gaskets are bad or dryrotting or something. not common unless the car has been sitting a long time. occasionally the housing can crack too.
Modified by limpmode at 12:14 PM 3/21/2006
Old Mar 20, 2006 | 12:31 PM
limpmode's Avatar
Default Re: possible bent valve? (limpmode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shooitslinh &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone give me some symptons of a bent valve?
https://honda-tech.com/zerothread?id=1565144
Old Mar 20, 2006 | 05:39 PM
Rosko's Avatar
how far off were the valves?
Old Mar 20, 2006 | 07:06 PM
prelude1897's Avatar
Try doing a valve adjustment, cause they're most likely out of sink....
RSXSisboss
K Series
Jan 28, 2014 09:44 PM
aavtec
19
Feb 18, 2013 04:20 AM
dhatcher2002
Nov 25, 2008 10:26 AM
mcgee*
Jun 30, 2005 03:31 PM
NiCkArInO
Mar 31, 2003 06:26 PM
