Starter troubles?
Old Mar 18, 2006 | 09:06 AM
kid-honda's Avatar
Default Starter troubles?
Alright I got a D16Z6 with a D16Y8 tranny.
I used a Z6 flywheel and a Y8 starter.
When I try and turn the car over the starter wines and wont turn over the flywheel but when I pull the starter out of the tranny the gear will engage like it should? but it wont when its in the tranny?
Is the starter just weak and I need a new one?
And yes the motor is good and can easily turn over so its not siezed.
Old Mar 18, 2006 | 07:22 PM
kid-honda's Avatar
Default Re: Starter troubles? (kid-honda)
bump
Old Mar 18, 2006 | 11:40 PM
Db1_77's Avatar
the starter is probably engaging the flywheel. Check your battery, grounds, and powers, make sure all DAT JANK is kickin hawt ya herd?!
Old Mar 19, 2006 | 01:44 AM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
mabey the bendix is fucked up
Old Mar 19, 2006 | 08:17 AM
kid-honda's Avatar
Default Re: (hatch77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch77 &raquo;</TD></TR><TR><TD CLASS="quote">the starter is probably engaging the flywheel. Check your battery, grounds, and powers, make sure all DAT JANK is kickin hawt ya herd?!</TD></TR></TABLE>
No with the flywheel inspection cover removed you can see it not moving but you can obviously hear its not.
Old Mar 19, 2006 | 11:05 AM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (kid-honda)
Try another starter.
Old Mar 19, 2006 | 01:27 PM
Db1_77's Avatar
perhaps it's grounding itself out on the transmission. Look and make sure all of your ground cables are intact.
Old Mar 20, 2006 | 03:29 PM
kid-honda's Avatar
Default Re: (Screwtape:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape: &raquo;</TD></TR><TR><TD CLASS="quote">Try another starter.</TD></TR></TABLE>
Not so easy when nobody hasd the old school d stuff layin around.
Old Mar 22, 2006 | 08:47 AM
kid-honda's Avatar
bump
Old Mar 23, 2006 | 06:50 PM
kid-honda's Avatar
Tryed another starter and I got the same problem any ideas?
G60
Oct 13, 2020 12:58 PM
Whiteranger
May 27, 2013 06:39 AM
Greyout
May 12, 2005 06:41 PM
MikekiM
Jan 18, 2005 09:47 AM
g2homboi
Jul 2, 2004 11:27 AM
