Please help -Honda Accord 1993 - Automatic - EX
Old Mar 18, 2006 | 07:40 AM
jojo69's Avatar
Default Please help -Honda Accord 1993 - Automatic - EX
Hi all,
My car just failed the AIM test (EPA requirements).
Test showed that the CO level is too high.
Also, I noticed that the car is not running well. It would not take gas at some point. It shocks. I have to remove my foot off the gas pedal in order to get back to normal.
Does the Catalytic converter have anything to do with this?
Any recommendation would be greatly appreciated.
Thanks,
Joey
Old Mar 18, 2006 | 08:04 AM
P_Adams's Avatar
Default Re: Please help -Honda Accord 1993 - Automatic - EX (jojo69)
The observation that your car failed the State of Ohio's AIM (automobile inspection and. maintenance) test is somewhat vague. The CO indicator may hint to what's going on. Here are some reasons that may cause it:
Carbon monoxide(CO) failure - exceeds established standards for carbon monoxide
Air to fuel mixture may be too rich.
Idle speed is not correct.
Air filter may be partially clogged.
Choke may not be operating properly.
Positive Crankcase Ventilation (PCV) valve may not be functioning properly.
Air or fuel problems, other equipment or engine malfunctions.
Catalytic converter may be partially clogged or not properly functioning.
Engine oil may be dirty and needs changing.
Various engine sensors may not be functioning.
Yes...............the converter COULD be a contributing factor....
P
Old Mar 18, 2006 | 08:30 AM
jojo69's Avatar
Default Re: Please help -Honda Accord 1993 - Automatic - EX (P_Adams)
Thank you for your quick reply.
Is there a way to narrow it down?
or
Is there a way to troubleshoot items on the list that you listed?
Thank you again
Joey
Old Mar 18, 2006 | 08:37 AM
bodiez's Avatar
Hit the floor!
I would say start with:
Check/change air filter
Adjust your timing
Clean out your EGR Valves (youll need replacement cork stoppers)
Change O2 sensor/remember when it was last changed
Change Oil
Old Mar 18, 2006 | 04:30 PM
P_Adams's Avatar
Check and make sure the engine's at full operating temp (thermostat's good), and you get it good & hot before you surrender for the inspection. If the engine's cooler that expected, the ECM's going to run it richer to compensate.....
P
Old Mar 18, 2006 | 05:45 PM
Dmc1's Avatar
Yeah man my cousin Bucky worked at the Local Echeck a few years ago before they did away with them here in kentucky.
Drive that car like you stole it for about 10-20 minutes before you take it in.
faran
Apr 25, 2015 08:31 AM
FaLKoN240
Feb 4, 2015 10:55 AM
denster
Oct 13, 2014 07:53 AM
atlthrasher
Dec 19, 2012 02:38 PM
