92 Cam Swap into 91
Old Mar 18, 2006 | 07:07 AM
2ndgentegracer's Avatar
Default 92 Cam Swap into 91
I put 92 cams into my 91 last night, and now my car is actually slower. I thought I would gain some power with the newer cams, but the motor falls flat on its face after 5K. I'm gonna mess with the timing on the distributor to see if I can make a difference. It feels like I went from 14.9 to 16 flat. HELP!!!!!
Old Mar 18, 2006 | 09:16 AM
projectTeG's Avatar
i wouldnt blame that increase in time on the cams, id say sonmething went wrong somewhere in the timing.
Old Mar 18, 2006 | 09:23 AM
Yoinked's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt blame that increase in time on the cams, id say sonmething went wrong somewhere in the timing.</TD></TR></TABLE>
I'm gonna have to agree...sounds like some mad retardation.
Old Mar 18, 2006 | 09:24 AM
JETSPD1477's Avatar
check both ignition and valve timing...
Old Mar 18, 2006 | 09:30 AM
subgeniusdude's Avatar
Default Re: 92 Cam Swap into 91 (2ndgentegracer)
Did you adjust the valves afterwards?I once put an Si cam in my 91 Civic STD and it ran like crap,put the old cam in and still ran bad...adjusted valves and voila!If someone says you don't need to do a valve adjustment after swapping cams they're mistaken.
Old Mar 18, 2006 | 10:08 AM
mr.beeks's Avatar
Default Re: 92 Cam Swap into 91 (subgeniusdude)
timming and valve adjustment has a lot to do with it....
Old Mar 28, 2006 | 05:44 PM
Default Re: 92 Cam Swap into 91 (mr.beeks)
I retimed the car today, and its a world of difference. Thanks for the advice guys.
Tarmac Junkie
Nov 13, 2006 08:35 PM
stevescivic
Sep 2, 2006 10:36 PM
90crxsib16
Jan 12, 2005 03:15 PM
hlhneast
Mar 1, 2004 08:54 PM
