Civic ej1, 16x7 subzero ET45. What tire size you recommend? :)
Old Mar 18, 2006 | 05:13 AM
ej2civic's Avatar
Default Civic ej1, 16x7 subzero ET45. What tire size you recommend? :)
Topic tells all..
Old Mar 18, 2006 | 06:29 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Civic ej1, 16x7 subzero ET45. What tire size you recommend? :) (ej2civic)
205/40-16 is the best 16" size for your '92-95 Civic.
Old Mar 21, 2006 | 11:25 PM
ej2civic's Avatar
Default Re: Civic ej1, 16x7 subzero ET45. What tire size you recommend? :) (nsxtasy)
ok, thanks
any more suggestions???
Old Mar 22, 2006 | 06:35 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej2civic &raquo;</TD></TR><TR><TD CLASS="quote">any more suggestions???</TD></TR></TABLE>
Well, I suggest you use 205/40-16. Or, you could use 205/40-16. A lot of good tires are available in 205/40-16. And 205/40-16 is a good size if you want to preserve the accuracy of your speedometer and odometer, since it's 0.8 percent smaller in outer diameter than your stock size. 205/40-16 is a good size to avoid rubbing. Did I mention that 205/40-16 is the best size for your '92-95 Civic?
Or, feel free to continue to ask for more suggestions. I'm sure others will be happy to recommend 205/40-16 too.
Old Mar 22, 2006 | 08:04 AM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Well, I suggest you use 205/40-16. Or, you could use 205/40-16. A lot of good tires are available in 205/40-16. And 205/40-16 is a good size if you want to preserve the accuracy of your speedometer and odometer, since it's 0.8 percent smaller in outer diameter than your stock size. 205/40-16 is a good size to avoid rubbing. Did I mention that 205/40-16 is the best size for your '92-95 Civic?
Or, feel free to continue to ask for more suggestions. I'm sure others will be happy to recommend 205/40-16 too. </TD></TR></TABLE>
These are all very interesting tire choices but have you also considered 205/40-16s? I hear those might also work in this case.
OP: Do you perhaps need suggestions as to what kind of tires to get? Like what make and model of tire?
Cheers
Old Mar 23, 2006 | 01:52 AM
ej2civic's Avatar
Default Re: Civic ej1, 16x7 subzero ET45. What tire size you recommend? :) (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">
Cheers</TD></TR></TABLE>
hehe :D OK OK Ill get 205/40-16...
Dunno about ame and model... Just some good street tires
Old Mar 23, 2006 | 08:35 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej2civic &raquo;</TD></TR><TR><TD CLASS="quote">hehe :D OK OK Ill get 205/40-16...
Dunno about ame and model... Just some good street tires </TD></TR></TABLE>
The Kumho Ecsta SPT is $74/tire in that size and is an excellent tire at a low price. So is the Yokohama ES100 for $82/tire.
Just don't use either one in snow. If you have to use the same tires in snow as in warm weather, then consider an all-season tire like the Kumho Ecsta ASX.
Old Mar 23, 2006 | 03:23 PM
ATL-Honda-Tuner's Avatar
The 205/45-16 will offer a better fit and less fender gap. I would reccomend those over the 205/40 16. Plus, you won't get quite as harsh of a ride and a little less pothole worries.
205/40 17 is good for 17" wheels.
plus, being that you are on a 7" wide rim and not 7.5" or 8" it is a more proper fitment.
Old Mar 23, 2006 | 04:40 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Civic ej1, 16x7 subzero ET45. What tire size you recommend? :) (ATL-Honda-Tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATL-Honda-Tuner &raquo;</TD></TR><TR><TD CLASS="quote">The 205/45-16 will offer a better fit</TD></TR></TABLE>
WRONG. 205/40-16 is a better fit. Here's how the outer diameter compares to the stock sizes for the '92-95 Civic:
175/70-13 stock (most models)
205/40-16 -0.8 percent
205/45-16 +2.7 percent
In addition to throwing off your speedometer and odometer, there is a much stronger chance of rubbing on the wheel well liners with the 205/45-16 (many Civic owners have found this).
For a '92-95 Civic:
205/40-16
205/45-16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATL-Honda-Tuner &raquo;</TD></TR><TR><TD CLASS="quote">you won't get quite as harsh of a ride and a little less pothole worries.</TD></TR></TABLE>
If you don't want as harsh of a ride or worries about potholes, you're better off getting 15" wheels instead of 16" wheels.
TougeCoupe
Jul 7, 2009 10:56 AM
demian22
Jan 27, 2009 06:21 PM
member EG
Feb 5, 2007 12:14 PM
draperj09
May 2, 2006 08:51 AM
tony n.
Dec 21, 2005 06:49 AM
