ITR vs CRVtec In my DA
Old Mar 17, 2006 | 11:09 PM
dahoopdahup's Avatar
Default ITR vs CRVtec In my DA
Well Im thinking of doing one of the two swaps in my DA. JDM ITR or CRVtec. Help me out on this one. Some people say Type R is faster others say CRVtec. What kind of numbers do you CRVtec people pull???
Old Mar 17, 2006 | 11:51 PM
watsvtecEK's Avatar
Default Re: ITR vs CRVtec In my DA (dahoopdahup)
It matters how built the crvtec is. and what head you are going to use.
Old Mar 17, 2006 | 11:58 PM
Default Re: ITR vs CRVtec In my DA (D 2da A9)
CRV botom end with B16 head. All stock.
Old Mar 18, 2006 | 12:11 AM
psychotic_z's Avatar
People don't recommend running a stock CRV bottom end with a VTEC head due to the piston speeds it'll see and the thin cylinder walls it has.
If you're not going to do it right, and by that I mean reinforced bottom end and correct LS/B20-VTEC install, do an ITR motor. Or just be happy with what you have
Old Mar 18, 2006 | 03:54 AM
Takumi Fujiwara's Avatar
Default Re: ITR vs CRVtec In my DA (psychotic_z)
search b20 vtec. alot of people use stock b20 blocks for NA, but would recommend sleeving for turbo. You're gonna get a ton of opinions, but ultimately, it's how much money are you willing to spend?
Old Mar 18, 2006 | 07:16 AM
CleanLikeJdm's Avatar
Hype-R Stalker
If you're cheap about building it, get the type-r.
more then likely you'll end up with more problems not building the crvtec,
then it being cheaper in the long run.
Old Mar 18, 2006 | 09:38 AM
Yoinked's Avatar
Default Re: ITR vs CRVtec In my DA (FlatBlackTeg)
IMO, leaving a B20 bottom stock and doing a head swap yields decent power and torque but without more compression you are limited to how much power will be made with supplimentary mods. Also the clearances on a B20 aren't nearly as close as a Type R's are so it won't safely rev as high or last as long being run at higher engine speeds.
Old Mar 18, 2006 | 01:33 PM
Default Re: ITR vs CRVtec In my DA (negtegra.)
Money is not to big a problem. I want somthing that can handle some abuse. Im leaning tward the type R. My buddy is doing a CRVtec in his DA. Just want to make sure I beat all my freinds!! LoL
I supose if you add up the money beefing up B20 theyre about the same.
Old Mar 18, 2006 | 03:07 PM
R6E6I6D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dahoopdahup &raquo;</TD></TR><TR><TD CLASS="quote">
I supose if you add up the money beefing up B20 theyre about the same. </TD></TR></TABLE>
o god no.
2 different beasts completely in and out
i would personally spend the cash on a b20vtec jsut get head studs rod bolts and the golden eagle kit and enjoy ...
if going b20 vtec i would suggest a block guard.. i am against these things but when reving high (8k) ur gunna want the extra support being that all other B series have 9 mm sleeves and the b20 has 6mm sleeves
i runa boosted b20 and have yet to run into any problems.
its daily driven and occasionally abused
Old Mar 18, 2006 | 06:42 PM
Brice.Hayden's Avatar
Default Re: ITR vs CRVtec In my DA (R6E6I6D)
that and stock b20 pistons yield low compression numbers which is dog w/vtec head. either go b20z pistons to get a 10.1 compression or go aftermarket for 11+ compression.
b20b pistons will leave you in the low 9cr and that sucks.
Old Mar 19, 2006 | 07:49 PM
Default Re: ITR vs CRVtec In my DA (JasperDA9)
I think I will just build an LSVtec/w Turbo and call it good. I can get one for dirt anyway. I waste to much brain power thinking of engine combos.
Old Mar 19, 2006 | 08:03 PM
Sic_DA_Nine's Avatar
id say get a type R...
buy something that is meant to have vtec. i think thats gunnabe more reliable then something that wasnt
Old Mar 19, 2006 | 08:05 PM
rkrone's Avatar
CRVtec!!! so much better, don't worry about the thin side walls, my b20z2 holds up just fine with a gsr head (w/itr internals) and good fuel management under 8-10psi t3/t4
i was happy with this set up NA, and with turbo i break traction over 6k with 205 wide tires....
b20 is also better for torque
Old Mar 19, 2006 | 09:58 PM
Spectrum24x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dahoopdahup &raquo;</TD></TR><TR><TD CLASS="quote">I think I will just build an LSVtec/w Turbo and call it good. I can get one for dirt anyway. I waste to much brain power thinking of engine combos.</TD></TR></TABLE>
Definetely just go for the LS/Vtec, it'll be more reliable then the CRVtec b/c the Ls is a stronger motor, and safer for the conversion.
I would recommend getting some forged internals, a block girdle, arp head studs, and resurface the head and block for safety reasons before you turbo it, and make sure it is all well tuned.
I have a 12.7:1 compression LS/Vtec that will kill type Rs
Old Mar 22, 2006 | 02:39 PM
Default Re: ITR vs CRVtec In my DA (Spectrum24x)
well... back to my original question:
Sock ITR b18c/w trans VS CRVtec/w stock b16 head and ls trans
witch one is the faster of the bunch. Does any one have dyno numbers for the CRVtec????
Old Mar 22, 2006 | 02:50 PM
RidinStock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dahoopdahup &raquo;</TD></TR><TR><TD CLASS="quote">well... back to my original question:
witch one is the faster of the bunch. Does any one have dyno numbers for the CRVtec????</TD></TR></TABLE>
Well the issue with that is the tranny. The LS has the longest gearing, the ITR has the shortest, so that isn't going to help.
Old Mar 22, 2006 | 02:56 PM
Default Re: ITR vs CRVtec In my DA (RidinStock)
Ok how about with a b16 trans??? I still think ITR would beat
Old Mar 22, 2006 | 03:19 PM
RidinStock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dahoopdahup &raquo;</TD></TR><TR><TD CLASS="quote">Ok how about with a b16 trans??? I still think ITR would beat</TD></TR></TABLE>
I don't know enough about the two motors to tell you honestly, just about the trannies. I have a b20b w/ a jdm ys1 tranny and it feels fast. It's really not though, at least not until my turbo kit is on. I've never experienced the b20z or b18c5, so I can't speak on either. Sorry.
Old Mar 22, 2006 | 04:03 PM
teggy182's Avatar
crvtec will yield you better torque figures. id say just get an itr head for the b20 and then your golden
JG_Restoration
12
Apr 12, 2014 11:00 AM
K7-1Ktrevor
May 3, 2010 04:54 AM
yoji
15
Dec 26, 2007 04:57 PM
allout_eg6
Apr 25, 2004 04:40 PM
done
May 23, 2002 03:29 PM
