BUILT LS VTEC SWAP 9:1 COMP GSR TRANNY 2900 NJ
Old Mar 17, 2006 | 09:42 PM
hotimportcrx's Avatar
Default BUILT LS VTEC SWAP 9:1 COMP GSR TRANNY 2900 NJ
2900 and its yours...UNBELIEVEABLE PRICE...only posting so low so i can sell it by like sunday....only thing needed is some lma's which are 65$ dirt cheap...and not hard to put in at all...there in the head
Ls Vtec
Ls block
B16 Vtec water pump
B16 Vtec oil pump
Oem Rod Bearings
Oem Main Bearings
Gsr Timing belt
Scat H Beam Rods
Micropolished Crankshaft
Mahle 9:1 Compression Pistons
Mahle piston rings
Unothadox Racings Crank Pulley
Fidanza 7.5lb flywheel
Act 6 puck unsprung Disk
Act Heavy duty pressure plate
Arp Rod Bolts
Arp Headstuds
Oem Modified Ls Headgasket
External Ls Vtec Oil Line
New Oil Pan Gasket
B16 Pr3-2 Vtec Head
Fresh Resurface
New OEM Gsr Distributor
Aebs Intake Manifold
Hayame Fuel Rail
Fuel Pressure Gauge And Modifier
Professional Powdercaoted Valve Cover(Type R wrinkle Red)
Head Tapped For Ls vtec
All Mated To a 1996 Gsr Transmission
Turbo PArts Include
Presicion sc60 Turbo
SMS Turbo Manifold
FMIC piping
Gm 3 Bar Map Sensor
Boost controller
Greddy Type s BOV
Turbonetics Deltagate Wastegate
Willing To trade for complete Stock Rsx type s swap into an eg
Pm me with offers
Motor has 800 miles encounting on it........
JDMCIVIC919
May 4, 2012 02:52 PM
hotimportcrx
Northeast (Sales)
Mar 27, 2006 06:51 PM
BOOSTEDgreeneg
Feb 15, 2006 03:42 AM
hotimportcrx
Feb 14, 2006 04:06 PM
