chipped ecu working on friends gsr but not my ls?
ok ill explain briefly. i have a chipped p06 converted to p28. it worked fine on my b16 last year. i have then changed motors to a 95LS. anyways it will not run good at all on the stockls.bin and throws a solid CEL. no blinking. i then take it out and throw a stock gsr bin into it and load it into my friends car and runs perfect. NO CEL. i then go back to my car and load the stock ls bin and same things runs terrible. does anyone know whats going on? it seems as though its only ment for a vtec car. i have tried every version of uberdata and like 20 different ls chips and they are run the same. extremely rich. am i missing something here. why is this happening? thanks
What version of UD are you using? 1.70+ have P75 "Import only" .bin's. Use a P72 .bin and turn the vtec, knock, and VTP off. Burn the chip and report back. I've always used P72 and P30 Maps as bases for non-vtec cars when using UD cause' the LS .bins in 1.70 and above do not run correctly.
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">Do your self a favor & try crome. </TD></TR></TABLE>
I had to do the same thing as described above w/ Crome as well.
Phil
hey thanks alot. ill try that. makes sense i guess. so this is what ill do
open UD
open stockgsr.bin
imort the p75 or no?
then ill unclick the options you told me
ill also change vtec enguage to 7999
open UD
open stockgsr.bin
londoncivic
Feb 1, 2008 12:20 PM
Acura_I-RS
Oct 30, 2005 09:06 AM
