HELP: turbo not spinning at idle....
Old Mar 17, 2006 | 06:31 PM
SPOON_BeIgHtEeNsEe's Avatar
Default HELP: turbo not spinning at idle....
the turbo is not spinning at idle when fully warmd up... spins past 1k rpms... but below it will not... could it be because of the oil return line... the oil return line sits slightly lower than the fitting where it goes back into the pan... could the oil be going back to the turbo and not returning back to the pan; causing it not to spin (too much oil)...? or are the seals bad... turbo is brand new just idled... if u give it gas it will spin again.... any help would be great...
Old Mar 17, 2006 | 06:32 PM
komat's Avatar
Default Re: HELP: turbo not spinning at idle.... (SPOON_BeIgHtEeNsEe)
what turbo and motor
Old Mar 17, 2006 | 06:36 PM
Default Re: HELP: turbo not spinning at idle.... (komat)
precision sc60 and d series y7block y8 head
Old Mar 17, 2006 | 06:48 PM
Ludman95's Avatar
I just helped in doing a sc61 setup on a h22 and it does not spin at idle.
Old Mar 17, 2006 | 06:59 PM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe &raquo;</TD></TR><TR><TD CLASS="quote">precision sc60 and d series y7block y8 head</TD></TR></TABLE>
its normal for a big turbo on a small motor
Old Mar 17, 2006 | 07:07 PM
ok so its not bad seals?
Old Mar 17, 2006 | 07:09 PM
Bailhatch's Avatar
search for "turbo spinning"
click archived
Old Mar 17, 2006 | 07:29 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe &raquo;</TD></TR><TR><TD CLASS="quote">ok so its not bad seals?</TD></TR></TABLE>
my t3t67 ho doesnt spin on my b16 either. it does but slow enough to see the baldes.
Old Mar 17, 2006 | 08:25 PM
jDMJeRk's Avatar
If it were bad seals, you would be leaking oil all over the exhaust housing usually
Old Mar 17, 2006 | 08:59 PM
A.E Motoring's Avatar
Default Re: HELP: turbo not spinning at idle.... (jDMJeRk)
i installed a tubo kit on a h22, and it barely spun, it was a brand new kit, nothing to worry about.
Old Mar 18, 2006 | 10:52 AM
traction issuez's Avatar
Default Re: HELP: turbo not spinning at idle.... (SPNFEDEH)
did you completly tighten your bolts on the compressor housing?
one time on my buddies integra, his bolts was all loose and one of them fell off - causing it to not spin during idle.
but like they say, big turbos and small engine - it's just not pulling enough vaccumm to make it spin!
-mike
Old Mar 18, 2006 | 10:59 AM
jfoster's Avatar
With the car off, make sure you can spin it with your fingers ... as long as it turns freely you should be fine.
My SC34 does not spin at idle on my LS.
Old Mar 18, 2006 | 11:08 AM
CoreyR's Avatar
Default Re: HELP: turbo not spinning at idle.... (boostedrotary)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedrotary &raquo;</TD></TR><TR><TD CLASS="quote">did you completly tighten your bolts on the compressor housing?
-mike</TD></TR></TABLE>
pulling enough vacuum?
i think you mean its not flowing enough exhaust gas
Old Mar 18, 2006 | 11:17 AM
Cyber ITR's Avatar
Default Re: HELP: turbo not spinning at idle.... (CoreyR)
thats weird
i have an sc61 with p-trim wheel , it spins on idle nicely just like ball bearing
i have a b18c1
Old Mar 18, 2006 | 11:36 AM
dpetro1's Avatar
Default Re: HELP: turbo not spinning at idle.... (jfoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster &raquo;</TD></TR><TR><TD CLASS="quote">
My SC34 does not spin at idle on my LS. </TD></TR></TABLE>
same here except on a gsr
Old Mar 18, 2006 | 11:56 AM
tallyturbo's Avatar
Default Re: HELP: turbo not spinning at idle.... (dpetro1)
do you know how a turbo work??? i guess not.
Old Mar 18, 2006 | 07:47 PM
jfoster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">
i think you mean its not flowing enough exhaust gas </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">
It would be a combonation of both vacuum and exhaust pressure. At idle a motor is in vacuum, naturally pulling air in through the turbo compressor housing. If it had more vacuum it could in theory suck air in through the compressor turbine blades fast enough to spin the turbine .... transversely if it were to push out more exhaust gas through the exhaust housing that too could make the turbine spin ...
Please attempt to think before ridiculing someone
Old Mar 18, 2006 | 07:53 PM
Bailhatch's Avatar
...or if its like most honda turbo setups, the blow off valve is open at idle and virtually no vacuum is pulled through the compressor.
Old Mar 18, 2006 | 07:58 PM
96 GSR-T's Avatar
Default Re: HELP: turbo not spinning at idle.... (Bailhatch)
If the BOV is open then wouldnt it be a good idea to put a filter on the BOV? or is sucking dirt into the engine through the BOV acceptable.
Old Mar 18, 2006 | 08:23 PM
jfoster's Avatar
Default Re: HELP: turbo not spinning at idle.... (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">If the BOV is open then wouldnt it be a good idea to put a filter on the BOV? or is sucking dirt into the engine through the BOV acceptable.</TD></TR></TABLE>
Thats a good point ..... I'm gonna have to go start my car and put my hand on the BOV and see if its suckin in ....
91-lsvtecsi
Aug 8, 2017 03:19 PM
notsolfast
Apr 8, 2012 10:18 AM
97grnrs
Feb 6, 2006 06:50 AM
Vtec92Civic
Apr 17, 2004 07:21 AM
