New Clutch install issues (with pic goodness)
I bought a new clutch and flywheel
got the clutch from here
https://honda-tech.com/zerothread?id=1503237 (thanks blueR for getting it here on time)
and the flywheel from here
http://www.racingworks.com/fid...l.htm
(my part number on the receipt is correct)
and heres whats happening
In the last pic i tried using a butter knife to show how much of a gap there is..
That cant be normal, can it??
I dont ever remember seeing something like that..though ive never installed a BRAND NEW clutch on a car..theyve always had some sorts of wear.
Thanks for any help I really wanted to get this installed tomorrow.
yeah the pins line up...and i just checked the number on the clutch kit
http://www.coximport.com/store/EX08800B
and its the correct one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">Make sure the dowel pins are lined up properly. It wont sit flush until the pressure plate is torqued to the flywheel.</TD></TR></TABLE>
yeah it won't sit flush until you torque the 12pt bolts down
but it seems that the gap is being cause by the clutch disc...if i remove the clutch disc the pressure plate mates perfectly with the flywheel..as soon as i put the clutch disc in it adds that gap..
thanks for the replieds guys
Joo have a manual? no? get one...
Yes? nm...
Criss-cross pattern---two torque sequences: first to 10 lbs
Start at the bolt you began w/ and follow the torque upto 19lbs
Grease the imput shaft, the the ball where the shift fork contacts and the inside of the thrust bearing.
Break the clutch in...for AT LEAST 350 miles...most recommend 750+ before driving aggressively. I skipped that part because I installed a clutch two days before a track day and now it whines...still looks goot, though. good luck.
Yes? nm...
I spent an hour enlarging the holes on mine before realizing it was supposed to be that way
as these guys have said, it's normal
an2ny888
Transmission & Drivetrain
Sep 7, 2010 08:58 PM
Cali Prelude
May 21, 2001 11:23 PM
