Re wire help needed " CRX"
Any one remember what pins need to be swapped when converting a CRX HF to run with a CRX D16a6? I remember the engine harness is diffrent as is the ECU wire configuration.
Car.... 89 CRX Hf
Motor...91 CRX si D16a6
engine harness- 91 CRX si
Car.... 89 CRX Hf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">use the HF engine harness on the Si and everything plugs right in and works with no wiring changes</TD></TR></TABLE>
Ok i will try that, thanks..
Well after a long hard look at the si vs hf harness i came up with ....
They are damn near the same the hf has two more plugs which are not used and my problem resulted from me not bolting down the ground lug on the thermostat housing" the one which supply's ground to the resistor pack". OOps..
So keep that in mind both harnesses will work just fine...
Thanks for the help guys.
crxb18a1
24
Aug 14, 2004 05:39 PM
