B18C1 Wiring help
Old Mar 17, 2006 | 04:16 PM
SystemShock's Avatar
Default B18C1 Wiring help
I am having a problem with the wiring harness on the B18C1 swap that I am doing on my 94 Civic Lx. The engine wiring harness does not match up to the wiring that goes from the ecu to under the hood were the enging wiringing plugs in. Any advice on what I need to do? Email me at LordDravenDakota@yahoo.com about this.
Old Mar 17, 2006 | 04:21 PM
pro1342's Avatar
what year motor and harness?
Old Mar 21, 2006 | 09:41 AM
Default Re: (pro1342)
The motor is a 94 JDM GSR B18C1 Vtec and it is going into a 94 Civic Lx.
Old Mar 23, 2006 | 11:40 AM
MrMike's Avatar
Default Re: (SystemShock)
u need a usdm gsr harness or modify your stock harness. Either way you will have to do some modifications. if u use your stock harness, u'll have to add vtec, vtec pressure, IAB, knocksensor wires all the way to the ecu, and extend various connectors. If u use a usdm GSR harness, u'll have to switch evap to IAB at the ecu and run wires for vtec, vtec pressure, knock, and EVAP from the shock tower connector, through the firewall to the ecu.
Old May 11, 2006 | 11:08 AM
Default Re: (MrMike)
How do I know if the harness is a JDM or a USDM?
crazy-teggy-ls
May 5, 2009 08:20 AM
aznwash3wboi
Dec 22, 2008 02:23 PM
ecksman
Nov 26, 2006 06:21 PM
17
Jul 10, 2006 08:51 PM
cubanbear16
May 21, 2006 11:42 PM
