INJECTOR SWAP. OBD0-OBD1 WIRE DIAGRAM
Old Mar 17, 2006 | 04:15 PM
payneth's Avatar
Default INJECTOR SWAP. OBD0-OBD1 WIRE DIAGRAM
Modified by payneth at 2:32 PM 12/9/2006
Old Mar 17, 2006 | 05:31 PM
payneth's Avatar
Default Re: INJECTOR SWAP. OBD0-OBD1 WIRE DIAGRAM (payneth)
bump.
Old Mar 17, 2006 | 07:16 PM
payneth's Avatar
Old Mar 17, 2006 | 07:23 PM
Blown90hatcH's Avatar
If you can hear your injectors over the engine sound....you have issues. But to help you out. The yellow wires with black stripes are the power wires on the injectors. The solid color wires go to the ecu. The colors will match on your current setup for the injectors. Just match them. You can also modify your stock injector clips to work with the OBD1 injectors.
As for the resistor box, remove it. Take the red wires and yellow/black stripe and solder them together.
Old Mar 17, 2006 | 08:30 PM
payneth's Avatar
Default Re: INJECTOR SWAP. OBD0-OBD1 WIRE DIAGRAM (Blown90hatcH)
goldex420
Sep 6, 2013 10:32 PM
i heart honda
Feb 14, 2009 03:46 PM
alpha_1
Jun 8, 2004 07:19 AM
schwett
Dec 30, 2003 01:38 PM
EGHatchy
Jul 13, 2002 08:53 AM
