help with tranny
ok so after last w/end i installed a new clutch kit on my car cuz the old one broke (spring on disk) even when it happened my car wouldn't engage in gears and i thought maybe cuz of the clutch goin out but after installin the new clutch kit i have the same problem the car will not go into any gear when the car is started but will go if the car is off....the clutch kit i installed was a Competition 6puck w/ pressure plate and Competition 11lb steel flywheel..please help me out on wha to do so i can get drivin again the motor is the jdm H22
i did bleed the slave but i was told the cylinder is still fine should i go ahead an attempt to still change it an see if this helps?
dont anybody know anyhing that could be of some help to me/?
i was told the fork could've been put bak in incorrectly which would also cause my problem???
will do i took the car to the shop today to get it goin so once they find out the situation i'll get a call from them
will the shifting lever go into position but the tranny doesnt engage......yes this part of my problem but it will only go in position when the car is turned off
should be pickin the car up from the shop Monday after work once i get a ride plus i gotta try an get out early in order to get the car but once i get there they will inform me on what was the problem plus i really wanna get the clutch broken in b/c i was informed NHRA is on sunday at Moroso Motorsports park in Palm Beach, FL and its not so far from me an i would like to run in the street/test n tune class. but i will post an update as soon as i bring home my baby along wit some pics....
i wanted to cuss the guy who told me how to install the clutch, the idiot had me install the clutch disk in backwards so that was my problem other than that i did everything perfect an the clutch n flywheel is soooo great. i ran a 95 240sx wit a stock SR20 motor leavin the shop an pulled on it 2 cars lol i love it.....
