1999 Civic DX rear brake assembly question
i have a 1999 civic dx with the original rear drum brakes. I know the 1999-2000 civic si brakes work for a disc swap, but what about 1994-2000 Integra rear discs? do those fit?
what would be a good rear brake swap for my car?
Also is the diameter of the front discs on a 1999 Civic DX the same as the 1999-2000 Civic SI? What are the differences?
I would like to stiffen up the car with swap bars, strut bars, etc... are their any other suggestions. I'm not looking to go super extreme, just possible a little auto-x every once in a while.
you can use rear disc from 88-00 civic and 94-01 teg.
as for the e-brake cable, you can techincally use the from the teg, but you have to cut it up, because it has a one-piece rubber boot when you connect it to the under body, you can use the on off of 99-00 Si, or 93-95 civic EX-ABS (that what i am currently using for my 00 HB)
good luck bro
good luck bro
gabbernaut
Aug 13, 2012 12:21 PM
blackjdmEKcivic
Oct 21, 2004 02:15 PM
