TONS OF B-SERIES & MISC PARTS!!! PICS...
TRYING TO CLEAN OUT MY GARAGE HERES WHAT I GOT...
I HAVE PICS OF EVERYTHING JUST ASK!!!
<u>GSR OBD1 & OBD2</u>
-GSR upper tranny mount $ 20
http://i11.photobucket.com/alb...7.jpg
-GSR Shift fork $ 15
http://i11.photobucket.com/alb...4.jpg
-GSR thermostat and fan switch $25
http://i11.photobucket.com/alb...5.jpg
-GSR oil pick up and baffle $30
http://i11.photobucket.com/alb...2.jpg
-GSR upper timing gear cover *cut* $15
http://i11.photobucket.com/alb...1.jpg
-GSR valve springs *outer only* missing 1 retainer * $20
http://i11.photobucket.com/alb...9.jpg
-GSR alternator plus brackets *plug cracked, Still works* $40
-GSR cams w/ gears *gears got rust on them* $60
<u>B-series </u>
-99-00 si driver side motor mount bracket $20
http://i11.photobucket.com/alb...8.jpg
-ITR valve cover Cut Cam Gear Cover
*painted Lime GREEN* $60
-98 b20b pistons no rods $ 25
-(2)b20b/z 84mm headgaskets used twice $35 a piece
-LS/B20 ARP head studs $60
-B-series timing belt gear - $15
http://i11.photobucket.com/alb...3.jpg
-B-series alternator mount $10
-Brand new 90-93 DA Hi performance brake pads
made by NISSIN $30
-Brand new 4x100 POWER SLOTTED ROTORS (civic's/integra)
One is for the Left and is 9 1/2 $40
One is for the Right and is 10 1/2 $40
<u>MISC</u>
-99-00 Si driver seat $30
-H3 Fog lights Brand New $20
http://i11.photobucket.com/alb...0.jpg
-H1 piaa lights Brand new $20
-2ton Foldable Engine Hoist *used 3times* $160 obo
<u>New parts added</u>
b-series Oil pan w/ oil pick up and baffle $60
b-series oil pressure sensor $15
b-series alternator backets top and bottom $20
b-series oil pump $35
b-series water pump $35
b-series belt tensioner w/ spring $20
b-series pulley $30
b-series thermostat housing & water neck complete $45
(3)b20z 84.5mm pistons w/ rods and bolts $40
b20b head w/ arp bolts $125
SHIPPING AT YOUR EXPENSE....
Modified by SpoonEk253 at 9:26 AM 3/22/2006
<u>B-series </u>
made by NISSIN $30
<u>MISC</u>
b-series pulley $30
Tell me more about the head studs for the b18b....how long/many times used....everything...all washers..nuts...ect..shipping quote
R.and.Y
Jun 22, 2007 09:00 AM
