Wilwood Brake Kit ????
Old Mar 17, 2006 | 11:33 AM
Evil_Ek's Avatar
Default Wilwood Brake Kit ????
I want to upgrade my brakes and i found a decent deal on a Wilwood brake kit ... what i wanted to know is if i will be able to fit a 15" wheel over them ? the rotors are 12.19" ....
Old Mar 17, 2006 | 11:44 AM
BlueIntegraBoy's Avatar
Default Re: Wilwood Brake Kit ???? (Evil_Ek)
I highly doubt it. The calipers will rub.
Old Mar 17, 2006 | 12:19 PM
AutoX_Acura's Avatar
There 11.1" kit will fit under 15's.
Old Mar 17, 2006 | 01:07 PM
-Gambit-'s Avatar
Default Re: (AutoX_Acura)
i am running the 12.2 inch kit and it barely clears my 16 with a +38 offset. It was such a tight fit that we had to move the wheel weights from the inside of the rim to the back lip. PM me if you have any question
Old Mar 17, 2006 | 01:32 PM
SOHC4life 96's Avatar
Default Re: (-Gambit-)
Gambit, that **** looks soo good.
OP: There is no way a 12" rotor will fit behind a 15" wheel.
Old Mar 17, 2006 | 01:33 PM
-Gambit-'s Avatar
Default Re: (SOHC4life 96)
thanks
Old Mar 17, 2006 | 01:47 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">Gambit, that **** looks soo good.
OP: There is no way a 12" rotor will fit behind a 15" wheel. </TD></TR></TABLE>
That's fine, because the rotor diameter doesn't have nearly as much effect on the braking power as the calipers and, if I recall, both the 11ish inch and the 12 inch Wilwood kits come with the same kickass calipers
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">That's fine, because the rotor diameter doesn't have nearly as much effect on the braking power as the calipers and, if I recall, both the 11ish inch and the 12 inch Wilwood kits come with the same kickass calipers </TD></TR></TABLE>
Good to know.
Old Mar 17, 2006 | 01:50 PM
-Gambit-'s Avatar
yep they both come with the very same 4 piston caliper
Old Mar 17, 2006 | 05:10 PM
fastbrakes's Avatar
There are a few 15" wheels that will clear the 12.2" set up if you get a lower offset. Team Dynamics Pro Race 1 15x7 will work.
Old Mar 17, 2006 | 06:55 PM
.Beaver's Avatar
Bloody Beaver
Default Re: Wilwood Brake Kit ???? (fastbrakes)
I knew a guy here that had that setup, he just ran 17's so he had no problems, but he was tired of having huge rims
Old Mar 17, 2006 | 08:16 PM
GSR95DXHATCH92's Avatar
i have had 17s and now i have 15s both have the same type of tire and as far as handling goes i love the 17s so get the big a$$ rotors and put 17s that is what i am going to do, but hey that is just my opinion. DO WHAT YOU WANT
Old Mar 17, 2006 | 08:17 PM
20_sec.hatch's Avatar
Default Re: (GSR95DXHATCH92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR95DXHATCH92 &raquo;</TD></TR><TR><TD CLASS="quote">i have had 17s and now i have 15s both have the same type of tire and as far as handling goes i love the 17s so get the big a$$ rotors and put 17s that is what i am going to do, but hey that is just my opinion. DO WHAT YOU WANT </TD></TR></TABLE>
Old Mar 18, 2006 | 07:19 AM
Evil_Ek's Avatar
yeah .. im planning on getting 16s soon ... but i have been debating 17s
Old Mar 18, 2006 | 07:39 AM
Evil_Ek's Avatar
what offset would i have to get to run a 15x8 with the 11.1" rotors ? and i know i will probably have to roll my fenders
Old Mar 18, 2006 | 09:06 AM
-Gambit-'s Avatar
Default Re: (Evil_Ek)
i have a +38 and it clears the calipers nicely
Old Mar 18, 2006 | 10:21 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
fastbrakes has a nice big brake kit for 15"
Old Mar 18, 2006 | 11:21 AM
dwolsten's Avatar
Default Re: (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">fastbrakes has a nice big brake kit for 15" </TD></TR></TABLE>
I believe the problem with the Fastbrakes kits is that they're extremely overpriced compared to Wilwood's own kit, considering they use most of the same parts.
2.0 and up
Suspension & Brakes
29
Aug 3, 2009 06:57 PM
20civic0000si
Apr 3, 2008 10:49 PM
white rocket
Jun 2, 2006 11:42 PM
RaVAGE00
Jul 7, 2005 06:40 PM
TRM04
Jan 8, 2002 07:50 PM
