removing amber from stock front corner lights
any ideas...i tried searching but nothing....instead of buying clear ones, just want
to know if there is an easier way to remove the amber....thanx
If it's a pre-96, I would honestly suggest you to spend $15 for some clear generic ones.
If they are 96+, do a search. There are billions of threads that cover this topic.
are you talking about the amber box on the inside of the stock corner lenses? If so, good luck then because I've tried to do that as well, and I thought I'd give the old "bake it for 5 minute" trick and it did not work. Somehow I don't think it was silicone that holds the lense over the piece and if it is, it's sure stronger than that of the headlights.
dirtyharryhatch
Nov 5, 2009 07:09 AM
EGcivicBoy
38
Dec 23, 2003 03:10 PM
