which guages are you guys running with?
i am thinking of running boost guage, a/f guage, oil pressure so far...any other suggestions?? do i need like any sort of temp. guages??
hopefully your thinking of going with an AEM or PLX wideband A/F gauge. the autometers are narrowband and read off of the stock o2.
i'd run exactly those, boost pressure, oil pressure, and wideband A/F display.
In order of importance:
1. Boost
2. Oil Pressure
3. Egt
I run Defi guages along with a PLX M-300 wide band
1. Boost
2. Oil Pressure
3. Egt
auto meter for me... cheap and good so far. also auto meter is probably one of the best companys to deal with, if your **** breaks you get a new one FREE!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97turboteg »</TD></TR><TR><TD CLASS="quote">auto meter for me... cheap and good so far. also auto meter is probably one of the best companys to deal with, if your **** breaks you get a new one FREE!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster »</TD></TR><TR><TD CLASS="quote">In order of importance:
1. Boost
2. Oil Pressure
3. Egt
1. Boost
2. Oil Pressure
3. Egt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cobra2326 »</TD></TR><TR><TD CLASS="quote">
excuse me?
</TD></TR></TABLE>excuse me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cobra2326 »</TD></TR><TR><TD CLASS="quote">lol, I guess that was kinda rude.
I really think EGT is near useless, IMO afr is the most important.</TD></TR></TABLE>
I can agree with that. If you have the $$$ for a wide band then EGT is not nearly as important .... I added the WB a while after the guages.
But when running without a WB an EGT guage can let you know if you start running dangerously lean in time to save your motor.
Zeitronix Display!
4 readings in 1. I would say EGT gauge is very important. The bolts to my turbo kept coming loose cause my EGTs were too high. Every couple of weeks I was loosing bolts. I added timing which brought the EGTs down and since then I never had that problem again. If I had no EGT reading I probably would have never figured out the problem. So I'll give the EGT gauge a BIG
from experience!
from experience!
lol. afr gauges are just as useless as egt gauges unless your talking about wideband
