piced up a welder and about to make........
Old Mar 17, 2006 | 06:26 AM
mrrugsr's Avatar
Default piced up a welder and about to make........
hey guys. i ran to homedepot and picked up their $250 flux welder. ive done some research on this but im fairly new on this subject. anything links or great info i need to help me with my new project. 3" Mildsteel downpipe and a 2" and 2.5 aluminum charge pipe. will i need special wire for the mild steel and then the aluminum? thanks guys
Old Mar 17, 2006 | 10:01 AM
mrrugsr's Avatar
Old Mar 17, 2006 | 10:21 AM
david@didrace.com's Avatar
Default Re: piced up a welder and about to make........ (mrrugsr)
If it's just a flux-cored welder have fun with the aluminum. You need shielding gas for aluminum (read: MIG, preferbly TIG for thinner materials).
Old Mar 17, 2006 | 10:43 AM
mrrugsr's Avatar
do i REALLY need the shielding gas?
What do u mean read mig and tig, is this a book or a post,etc?
Old Mar 17, 2006 | 10:44 AM
dfoxengr's Avatar
Default Re: (mrrugsr)
you need to just return that welder and pay someone to make the welds for you.
you cant weld aluminum with that.
Old Mar 17, 2006 | 11:04 AM
8mpg's Avatar
Default Re: (dfoxengr)
I totally agree...
An arc welder is made for welding submarine hulls and skyscrapers...not turbo piping
Old Mar 17, 2006 | 11:17 AM
vr6chris's Avatar
Default Re: (8mpg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8mpg &raquo;</TD></TR><TR><TD CLASS="quote">I totally agree...
An arc welder is made for welding submarine hulls and skyscrapers...not turbo piping</TD></TR></TABLE>
what the hell are you talking about? First off, he didnt buy a stick welder, he bought a mig that has no attachments for running a gas setup, so its only using flux core wire. Also, stick welding can be used to do a lot more things than industrial type welding. Please get your facts straight
Old Mar 17, 2006 | 11:21 AM
dfoxengr's Avatar
Default Re: (vr6chris)
no stick is pretty useless in all auto applications i can think of.
Old Mar 17, 2006 | 11:25 AM
mrrugsr's Avatar
its not stick its flux wire and YES there ARE NOT any attachments for gas.
OK so if i cant do my aluminum pipe then i can still do my Down pipe and catback (mildsteel)
paid a little over 300 for it. muffler shop wanted 25bux per weld. i probably have about 15-20 welds
Old Mar 17, 2006 | 11:27 AM
dfoxengr's Avatar
i know its not arc.
but seriously you should still return it and get something like a gassed hobart 140...
i would actually even take an oxy setup over that one.
but then again i can weld pretty well with oxy.
Old Mar 17, 2006 | 11:41 AM
essex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr &raquo;</TD></TR><TR><TD CLASS="quote">then i can still do my Down pipe and catback (mildsteel)
Yes you can.
Old Mar 17, 2006 | 11:51 AM
8mpg's Avatar
LOL
sorry, Im retareded and didnt read it right
Flux core will definately work but be prepared to do some metal cleaning. To me the biggest drawback of a flux core is the sputter when you weld. I would definately look into a gas conversion if the machine is capable of it and you want to keep it. Its almost impossible to weld alum without some major sheilding gas
Old Mar 17, 2006 | 11:55 AM
dfoxengr's Avatar
Default Re: (8mpg)
or a spool gun.
Old Mar 17, 2006 | 12:02 PM
mrrugsr's Avatar
i can always return it and get a gased one for the same amount. think i should?
more possiblities?
what gases would i need then
Old Mar 17, 2006 | 12:14 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">but seriously you should still return it and get something like a gassed hobart 140...
youll need 75/25 argon co2 mix. talk to a welding supply store, lots of times the bigger ones beat prices, even on the internet and will give you a deal if you get the machine and gas from them..
Old Mar 17, 2006 | 12:27 PM
mrrugsr's Avatar
welding place huh, ill have to find one around here
Old Mar 17, 2006 | 12:29 PM
dfoxengr's Avatar
http://www.yellowpages.com
Old Mar 17, 2006 | 12:39 PM
mrrugsr's Avatar
DUR
thanks man
Old Mar 19, 2006 | 03:59 PM
TurboInteg95's Avatar
You might want to check out eBay too. I got a pretty good deal (I think) on a Hobart Handler 140 from Toolking. It's a factory refurb but it looked pretty new to me. Also, I think it had the same warranty as a new one. However, I don't expect a it to be breaking on me anytime soon as Hobart is a respectable name. Anyway, it was $401 shipped and that included the regulator and gas hose. I just need a bottle now. I tested it out today for the first time on some .065 square steel tube and I must say that welding without shielding gas is pretty ***.
Old Mar 19, 2006 | 04:06 PM
mrrugsr's Avatar
is that gas expensive?
Old Mar 19, 2006 | 07:22 PM
HickamHatch's Avatar
gas on my 40cu ft is $15 a fill from Airgas
Old Mar 19, 2006 | 08:10 PM
8mpg's Avatar
Default Re: (93civic96ls)
but hes gotta buy a cylinder...so tack on another $80
If you can return it and get one capable of gas...do it, even if you dont use gas for now. Trying to weld aluminium though is almost a waste of time. you need the super helium shelding gas which is expensive and a different spool gun and wire to weld it. The aluminium wire is like limp spaghetti and isnt going to flow out of as steel wire piece.
Old Mar 20, 2006 | 08:47 AM
Everyones Hero's Avatar
Default Re: (8mpg)
My buddy's dad just bought a small (waist high) tank that was 75 Argon 25 CO2 for $50. He bought the tank and had it filled for $50, didn't rent it.
I used a Harbor Freight fluxcore welder on my mildsteel downpipe and intercooler piping. Make sure the wire feed isn't too fast because you will get a lot of splatter.
Welding Al w/ a fluxcore is damned near impossible.
I don't know much about welding, but my friend's dad said that TIG is best for Al, and that you should use 100% Ar.
I'd take back the one you have and get a gas welder. You also have to pick up the appropriate wires for Mild Steel and Aluminum.
Old Mar 20, 2006 | 09:28 AM
autosport7's Avatar
I am not sure I would waste my money on a mig if you plan on making charge piping and exhaust .... I did and now i have a miller 251 that collects dust .. go with the linc 185 i picked it over the mill 180 I got it a lil cheaper with more options
Old Mar 20, 2006 | 09:41 AM
Default Re: piced up a welder and about to make........ (autosport7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autosport7 &raquo;</TD></TR><TR><TD CLASS="quote">I am not sure I would waste my money on a mig if you plan on making charge piping and exhaust .... I did and now i have a miller 251 that collects dust .. go with the linc 185 i picked it over the mill 180 I got it a lil cheaper with more options</TD></TR></TABLE>
I agree. If you're going to use it once and then never again I'd get the cheapest thing that'll do the job. How many aluminum bends do you have? I had a local guy do 3 or 4 welds for only $20, but he was an older guy and he did the welds in his shop w/ no AC in the middle of a summer day for me, so I gave him $40.
