ww rs lip (tape)
Old Mar 17, 2006 | 05:50 AM
shutta's Avatar
Default ww rs lip (tape)
what is some decent tape to use for putting this lip on? wings west went under so I can't contact them.. i'm also putting this in the appearance/cosmetic forum to get feedback from them too. also, what shoudl I use to repair cracks/holes in this lip? it's urethan ein case you didn't know.. thanks
Old Mar 17, 2006 | 08:06 AM
prahjekt's Avatar
Default Re: ww rs lip (shutta)
If I was you I'd take it to a body shop that knows how to install lip kits. The extra money you'll spend to have someone do it right the first time will pay off in the long run. I learned that the hard way.
Old Mar 17, 2006 | 08:43 AM
chitownrida's Avatar
3m double sided, from the hardware store
get the red one
not the green one
Old Mar 17, 2006 | 08:46 AM
H20too's Avatar
Default Re: (chitownrida)
i have about 15 screws holding my front lip on, unnoticeable i may add...
Old Mar 17, 2006 | 09:01 AM
shutta's Avatar
well I pulled a wwrs lip off an extra bumper that someone had riveted it to and used screws in the middle, the screws pulled the lip up off the bumper in whatever way it wanted to, i'd have to look at it because I can't remember what there was to screw into, but it seems like such a pain in the ***, i definatly liek the piece of mind knowing the lip is more than just taped onto the bumper, but screws would probably pull it out of wack... where are the screws in yoru lip? how many?
Old Mar 17, 2006 | 10:10 AM
M2B4's Avatar
Default Re: (shutta)
i would tape it and then screw it in the holes from where the oem lip was and use the metal clips to hold the screws
Old Mar 17, 2006 | 10:17 AM
bboixtc's Avatar
Default Re: (M2B4)
wings west is back.
heres the instructions.
http://www.wingswest.com/pdf/9...2Epdf
Old Mar 17, 2006 | 10:57 AM
equinox's Avatar
on top of the 3m tape, use an adhesive promotor. It makes the lip stick like concrete.
Old Mar 17, 2006 | 12:27 PM
prelude1897's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitownrida &raquo;</TD></TR><TR><TD CLASS="quote">3m double sided, from the hardware store
get the red one
not the green one
Exactly, and be sure its the heavy duty tape and you clean the surface before putting it on.....No need to waste money taking it to a body shop, you can just do it yourself
Old Mar 17, 2006 | 01:15 PM
M2B4's Avatar
Default Re: (prelude1897)
for xtra tuffness you can rub a sealing primer down. its sold at many stores. we have it at home depot we put it between 2 cement blocks and now its almost impossible to get them apart.
Old Mar 17, 2006 | 02:34 PM
shutta's Avatar
weird, i went to the wings west site a few days ago and the installation page I saw was different from that, it dind't even say anything about 3m tape and was pretty detailed and 3 pages long
BAMA4792
Jul 21, 2007 07:18 PM
shutta
Mar 18, 2006 01:09 PM
sk8shorty012
Feb 6, 2006 06:06 PM
honda_coupe
Nov 1, 2005 04:20 PM
