Please help
Old Apr 1, 2002 | 07:16 PM
C4wrx's Avatar
Default Please help with intake manifold hose missing, dont know where it goes
ok, i have a 94 gsr engine with a skunk2 intake manifold
a part is sucking in air but there is no hose on it
i dont know what its called but it connects the sensor on top of the throttle body and and in back of the intake manifold, its black and has a sensor plugged into it, one part of it has a hose going to the back of the intake manifold, and the other going to the sensor on top of the throttle body, its sucking in air but there is nothing connected to it, does anyone know what else is supposed to be connected to it besides those 2????
[Modified by Jdmb18c, 7:08 AM 4/2/2002]
Old Apr 1, 2002 | 10:08 PM
C4wrx's Avatar
Default Re: Please help with intake manifold hose missing, dont know where it goes (Jdmb18c)
anyone??
Old Apr 2, 2002 | 06:06 AM
GTM's Avatar
GTM
That shold be it if you are talking about the IAC Valve behind the intake manifold. It is a common problem that the hoses crack and eventually leak vacuum. Check your connections. What are the symptoms? Are you idling extremely high?
Old Apr 3, 2002 | 12:46 AM
C4wrx's Avatar
i found the part whree it goes, it came from a hose from a filter under the manifold, it the idle was at 1k instead of around .75
dc2guy
Jul 9, 2006 12:05 AM
oblique
Sep 14, 2004 03:44 AM
mike34655
Aug 23, 2003 04:07 AM
C4wrx
Apr 2, 2002 03:52 AM
