Chicago Illinois 2000 ITR Bare Block, B18c 85mm DART Block, 99 B18C1 GSR longblock
DART Cast 85mm bore iron sleeved block. This is a cast virgin aluminum block that goes for $2300 brand new. It comes with main caps and bolts, oil squirter plugs and rear breather plug. Block needs a fresh hone. more info on this block can be found here http://www.dartheads.com/hondab.aspx
$1200 pick up only
GSR long block is sold..
Modified by 00ITR #543 at 11:36 AM 6/26/2006
is there any title or receipt to prove that the GSR block is legit? if so, might be interested...
You can run a car fax on the vin #, which is still on the block... Let me know if you are interested. i bought it from a shop owner here on h-t
all ims replied too. Please check post. there is a update on the 99gsr block...
i tried calling you, could probably come pick it up tonight, get back to me, i will try calling you again
This guy is a great guy to do business with, just recently bought the gsr longblock and he was excellent, would recommend to do business with him.
