h22 oil pan differences?
Old Mar 16, 2006 | 08:50 PM
momstaxi's Avatar
Default h22 oil pan differences?
just wondering if anybody knows if honda uses different oilpans between various h22 motors, or are they all the same?
Old Mar 17, 2006 | 09:01 AM
LudeyKrus's Avatar
IIRC, the older H22A1's were to be used with a rubber gasket, so they were a bit more shallow to compensate.
The older H22A4's were designed just to use the silicone sealant as the gasket, so they were made a bit deeper to compensate.
Old Mar 17, 2006 | 05:45 PM
momstaxi's Avatar
Default Re: (LudeyKrus)
ohh, i see thanks
Old Mar 18, 2006 | 12:49 AM
PrettyLude's Avatar
the obd1 lude engines have steel pans, and the obd2 engines have aluminum pans
Old Jun 15, 2006 | 03:31 PM
crj_lll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">IIRC, the older H22A1's were to be used with a rubber gasket, so they were a bit more shallow to compensate.
The older H22A4's were designed just to use the silicone sealant as the gasket, so they were made a bit deeper to compensate.</TD></TR></TABLE>
Does anyone know if the the H22A1's oil pan will work on a H22A4 for increased clearnce?
bp
10
Feb 15, 2008 08:22 AM
2quik
Jul 20, 2005 04:46 AM
Monkey Fing a Coconut
Oct 29, 2004 05:31 AM
staticrex
Jun 17, 2004 11:00 AM
JDubya
Oct 19, 2003 07:17 PM
