5th gen rear engine mount?
Old Mar 16, 2006 | 08:47 PM
momstaxi's Avatar
Default 5th gen rear engine mount?
just wondering if anyone knew why, on manual transmission models, 94-97 accord dx/lx rear engine mounts are different than 94-97 ex rear engine mounts?
Old Mar 16, 2006 | 09:50 PM
P_Adams's Avatar
Default Re: 5th gen rear engine mount? (momstaxi)
Harder (higher) Durometer* values (stiffer dampening medium) I would think.
P
* What is durometer?
Durometer is a measure of surface resistivity or material hardness. There are various instruments or gauges used to test durometer. Acor's durometer measurements are given in the " Shore A" scale. Actual product durometer readings can vary by 5 units (+ or -). Use these measurements as a guide to the RELATIVE softness of our materials.
Old Mar 16, 2006 | 11:43 PM
raceACCORDingly's Avatar
I think so too, P.
The EX 5spd rear mounts are kind of shapped like the 5th gen automatic tranny rear mounts, just without the vacuum controlled diaphram actuator. Why? My guess is for comfort reasons. Maybe that mount design provides better dampening/comfort.
But the EX mounts look so much weaker than LX/DX mounts and if you wanted to stiffen them up, Prothane (the only company I can find that makes rear inserts for our cars) only makes the inserts for the LX/DX mounts.
I am going through the painstaking task of swapping out my EX rear mount and bracket for a LX rear mount and bracket because I'm soon to be turbo'd and want to eliminate as much wheel hop as I can, and also because I might have to lose the front mount with the way my manifold is designed so I solidified the rear and side mounts in hopes of compensating for the front, kind of like h22 swapped Civics that have only aftermarket rear and side mounts.
LX mount before:
LX mount after:
However, I just picked up a cheap Harbor Frieght 4.5" angle grinder with metal cutting and grinding wheels so I may be able to keep some of my front mount.
Old Mar 17, 2006 | 04:15 AM
P_Adams's Avatar
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">I am going through the painstaking task of swapping out my EX rear mount </TD></TR></TABLE>
Not only PainSTAKING, but PainFUL task..... as well.
You may end up enlisting the support of an additional Wrench Monkey for your efforts
P
Old Mar 17, 2006 | 05:47 PM
momstaxi's Avatar
Default Re: (P_Adams)
ohh, i see...that makes sense (comfort)
so, the rear mount brackets are different as well as the mount itself i assume...
Old Mar 17, 2006 | 09:24 PM
P_Adams's Avatar
Default Re: (momstaxi)
Let's Find out:
'97 LX (manual)
B 50827-SM4-000 / BRACKET, RR. ENGINE MOUNTING (MT)
M 50810-SV4-000 / MOUNTING ASSY., RR. ENGINE (MT)
'97 LX (auto)
B 50827-SM4-J83 / BRACKET, RR. ENGINE MOUNTING (AT)
M 50810-SV4-J82 / RUBBER, RR. ENGINE INSULATOR (AT)
'97 EX (manual)
B 50827-SV4-J00 / BRACKET, RR. ENGINE MOUNT (MT)
M 50810-SM4-J03 / RUBBER, RR. ENGINE INSULATOR (MT)
'97 EX (auto)
Conclusions:
Automatic versions of both B1 (EX) and B2 (LX) use the same Bracket & Mount.
Manual version do not. They share nothing between the four samples.
P
Old Mar 18, 2006 | 01:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Not only PainSTAKING, but PainFUL task..... as well.
P</TD></TR></TABLE>
I hear ya. But it can't be as bad as my experience doing an auto to manual transmission conversion solo.
I really wish I would have done this mount swap when I did my auto to manual transmission conversion 2 yrs ago, it would have been so simple w/ the tranny out but at the time I was no where near close to thinking about going turbo.
Modified by raceACCORDingly at 10:32 AM 3/18/2006
GK2
Jul 13, 2023 12:00 PM
InTheZoneAC
Mar 31, 2014 08:11 AM
R THIS
Mar 28, 2005 11:07 AM
2000Accord5sp
Apr 23, 2003 09:41 PM
scrubachu
Apr 21, 2002 08:39 PM
