SOHC D16 Turbo Stuff, injectors, intercooler, piping, BOV, MBC, oil line kit
Old Mar 16, 2006 | 06:21 PM
The Mista Mike's Avatar
Default SOHC D16 Turbo Stuff, injectors, intercooler, piping, BOV, MBC, oil line kit and MUCH MORE!!!
Here's what I have for sale:
-550cc RX7 Saturated (High Impedance) Fuel Injectors with clips $125 **SOLD**
-Greddy/Trust D Series Cast Turbo Manifold Tapped for a T3 $175
-T3 52 Trim Turbo from a Volvo. Has some very slight shaft play, but that should be minimized when some oil is run through it. No in and out play. Comes with internal wastegate flapper assembly and actuator. It has also been machined to fit a standard T3 flange without any problems. Manifold and turbo would be a good combo. $175
-2" Polished intercooler piping. Some dings but should be fine. Comes with a 1g DSM BOV (I believe it has been crushed, but not sure) and some older couplers and clamps (may need to be replaced, but probably useable). $175
-Front Mount Intercooler 23.5 x 6 x 3.5" core with 2" inlet and outlet. A couple of bent fins, but nothing major. $175
-New ARP Headstuds for D series engines $80 **Sold locally**
-New 96-00 Honda OEM timing belt $25
-New (but opened) 96-00(??) Block gasket kit $25
-New (but opened) Hallman ES Manual Boost Controller $85
-New (but opened) Tuner Toys/Stealthmode Performance Oil Line Kit $85 **SOLD**
-Single cam Honda OEM catalytic conveter $20
-96-00 Civic Dual Gauge Pod Bezel $25 **Sold locally**
-2 Goodyear Victor V R430 Road Racing Slicks. Really good tread still left on them. Unmounted. $150
-2 20x6x14" Mickey Thompson Drag slicks. Again, really good tread on these. One of the sidewalls blew out, so these have tubes inside of them. I have ran them as low as 10.5 psi and had no problems with them. I would recommend running a little higher pressure, though. Sticky as hell. Mounted on VW rims. $150
-T3 turbo oil inlet flange $15 **SOLD**
-2.5" Flex pipe $10 **Sold to joshb_**
-92-00 Civic Tanabe Super Down Precedo Springs $65
-95 Prelude A/T Resistor Box $25
-T25 Hot Side $15
No pics of the following, yet:
-Civic HX exhaust manifold with cat in it. $200 with heatshield
-D series 4-2-1 2-piece header. Kinda dented and rusty, but it works. $50
Modified by Mistamike17 at 12:09 AM 3/20/2006
Modified by Mistamike17 at 12:57 AM 3/20/2006
Modified by Mistamike17 at 10:06 AM 3/21/2006
Modified by Mistamike17 at 10:15 AM 3/21/2006
Modified by Mistamike17 at 11:14 AM 3/25/2006
Old Mar 16, 2006 | 08:47 PM
importdude2000's Avatar
edit.. i had to flake and i im no longer buying it.. good seller!
Modified by importdude2000 at 4:31 AM 3/17/2006
Old Mar 16, 2006 | 09:14 PM
Default Re: (importdude2000)
Thread updated... Oil line kit sold.
Old Mar 16, 2006 | 11:04 PM
read pm plz
Old Mar 17, 2006 | 03:23 AM
Replied.
Old Mar 17, 2006 | 03:26 AM
Default Re: (Mistamike17)
Oil line kit back for sale
Old Mar 17, 2006 | 03:43 AM
LaOstha's Avatar
is 175 the price for mani and turbo
Old Mar 17, 2006 | 05:39 AM
Default Re: (LaOstha)
No, 175 for each. If you want both, you can have them for $300.
Old Mar 17, 2006 | 07:51 AM
Bump.
Old Mar 17, 2006 | 08:35 PM
Bump for a UK win.
Old Mar 18, 2006 | 07:58 AM
PMs replied.
Old Mar 19, 2006 | 08:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistamike17 &raquo;</TD></TR><TR><TD CLASS="quote">PMs replied.</TD></TR></TABLE>
Old Mar 19, 2006 | 01:23 PM
All questions answered. Bump for OBO.
Old Mar 19, 2006 | 06:13 PM
Bump again.
Old Mar 19, 2006 | 08:09 PM
Bump for pics.
Old Mar 20, 2006 | 03:31 AM
Bump in the morning.
Old Mar 20, 2006 | 06:37 AM
Bump
Old Mar 20, 2006 | 11:10 AM
Bump, probably going on ebay here shortly.
Old Mar 20, 2006 | 12:06 PM
Ok.. the intercooler, piping, BOV, and turbo are now on eBay.
Old Mar 20, 2006 | 06:24 PM
Bump again.
Old Mar 21, 2006 | 03:16 AM
Bump it if you looked!
Old Mar 21, 2006 | 03:54 AM
darkcvc's Avatar
Blue Sedan Crew
can you pm a price for all the turbo stuff together, I can't do pm's at work, thanks
Old Mar 21, 2006 | 05:54 AM
joshb_'s Avatar
ill take the flex pipe.....pmed
Old Mar 21, 2006 | 06:02 AM
Default Re: (joshb_)
All PMs replied. I'm throwing some good deals out. Hit me up while I'm in a selling mood.
Old Mar 21, 2006 | 06:09 AM
Thread updated. Flex pipe pending.
