CEL after d16y8 motor swap... can't pull a code...
Old Mar 16, 2006 | 05:12 PM
btleier's Avatar
Default CEL after d16y8 motor swap... can't pull a code...
Hey guys quick question. Over the weekend we put a d16y8 into my 92 hatch. The motor starts and runs pretty well. However, I have a check engine light haunting me. The check engine light won't come on until the car has been running for like 5-10 seconds, and if I try to pull the code it just stays solid. One thing you should know if I'm running open header until I get my exhaust done on monday. Would that be why, or what else can I check?
Old Mar 16, 2006 | 06:24 PM
btleier's Avatar
no ideas? come on guys help a noob out.
Old Mar 16, 2006 | 06:40 PM
pro1342's Avatar
what computer?
Old Mar 16, 2006 | 07:08 PM
btleier's Avatar
p28
Old Mar 16, 2006 | 08:29 PM
btleier's Avatar
up for some help.
Old Mar 16, 2006 | 09:32 PM
siege911's Avatar
got all the o2 sensors hooked up? you said open header right?
Old Mar 16, 2006 | 11:42 PM
btleier's Avatar
all of them? how many should there be? I have the one going into the header hooked up. it is currently open header until my exhaust appointment on monday.
Old Mar 17, 2006 | 02:42 AM
Eaglekper0046's Avatar
Default Re: (btleier)
usually a solid code is the ecu is bad.
blkonblkhatch's Avatar
I'm not positive on this, but I read somewhere if your cel stays on and you cannot pull a code it could possibly be a bad ecu.
Old Mar 17, 2006 | 04:41 PM
btleier's Avatar
n/m guys I got it figured out.... there was just a loose connection on the toggle switch that was acting as my jumper... repaired that connection, and it pulled just fine. CEL #41... Primary Oxygen Sensor heater...
Delsolbonez
12
Mar 12, 2013 03:24 AM
my94d16y8coupe
Feb 12, 2011 04:16 PM
seanewing
Apr 29, 2010 12:18 PM
OneBadVTEC
Jun 16, 2006 05:34 AM
