turbo parts list
you will need a turbo, downpipe, charge pipes, FMIC or SMIC (intercooler) probably will need to do something to bypass the ecu reading the boost. you will need to tap your oil pan with 2 different lines....feed and return, depending on what kind of turbo you use....some need a turbo timer ...some are cooled with coolant ....try a emanage from greddy just buy a kit. or try http://www.homemadeturbo.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar_ek »</TD></TR><TR><TD CLASS="quote">bigger injectors too..</TD></TR></TABLE>
yeah but that depends on what kind of fuel management we're talking about here.
To the OP: It sounds to me like if you're going to be turbocharging your car, you need to have done at least enough research to know what parts you are going to need to actually do it.
Check out the forced induction forums, do your research, you'll be glad you did.
andreysibiris
13
Jan 17, 2006 12:03 PM
