HELP Intake Manifold problems!!!!!!
Old Mar 16, 2006 | 04:36 PM
Big Wood's Avatar
Default HELP Intake Manifold problems!!!!!!
Ok guys i just installed the skunk2 IM and password jdm intake and im having some problems. i need your help, it keeps changing idle frome low to high and running funny also at 1500 it pulses like i have a leak but i know i dont. the cel is on and it says IAT sensor malfunction and another code i know i need a tune any ideas for help alos i want hondata what do i need the basic unit and a obd2 to obd1 harness, anything would help PLEASE...
Old Mar 16, 2006 | 04:57 PM
Big Wood's Avatar
Default Re: HELP Intake Manifold problems!!!!!! (Big Wood)
anyone i need help please
Old Mar 16, 2006 | 06:18 PM
:Andrew's Avatar
what motor?? what car??
Old Mar 16, 2006 | 06:21 PM
b18ccivics's Avatar
Default Re: HELP Intake Manifold problems!!!!!! (:Andrew)
you have a leak, you dont need "tune" with just an intake mani and pipe
Old Mar 16, 2006 | 07:14 PM
Big Wood's Avatar
98 gsr motor with 113k miles, there is no leak it only pulses at 1500 rpm no more no less i had a leak but fixed it i dont just have intake and mani also skunk2 stage 1 cams, aem adjustable cam gears fuel rail and fpr header and exhaust theres others but im running stock fuel managment could this be a problem. i wanna get hondata but honestley have no idea what i need!!!!
Old Mar 16, 2006 | 08:00 PM
IntegraType-R's Avatar
Default Re: (Big Wood)
u changed your manifold, almost 100% postivie leak around the manifold common sign, check your hoes, and the manifold itself, good way to see if the manifold is leaking threw the gasket, take some WD-40, or Chem b12 choke cleaner and spray around the awhole manifold, when i say manifold, aim it towards where it attaches to the head,and spray, if it starts to spit and sputter, your either not tight enough and / or you have a gasket leak somewhere and you didn't scrap enough of the old gasket off..try that see if it helps.,,
Old Mar 16, 2006 | 08:22 PM
Big Wood's Avatar
thats what i did thats how i found out i had the first leak when it wouldn't stay running. i just dont know what it could be.
jdmable
Feb 12, 2008 01:33 PM
miguel329
Jan 27, 2008 09:25 PM
teamOREO*JP
May 28, 2005 06:43 AM
AK94GSR
Sep 21, 2001 03:58 PM
