B series oil pans?
Old Mar 16, 2006 | 03:31 PM
mportracer33's Avatar
Default B series oil pans?
What b series oil pans are interchangeble?
I have a gsr oil pan that needs to go onto a b16 and I am using the b16 oil pan on my gsr..will it work?
if not what oil pans can I try?
Old Mar 16, 2006 | 03:33 PM
Schister66's Avatar
Man U FTW
i would assume so since everything else pretty much is....
Old Mar 16, 2006 | 03:38 PM
Default Re: (Schister66)
u sure? cause someone was telling me that the oil pickup is different? but they werent sure..
Old Mar 16, 2006 | 04:45 PM
Boosted2K's Avatar
Default Re: (mportracer33)
pickup is not the same
Old Mar 16, 2006 | 06:11 PM
Slappy's Avatar
Default Re: (Boosted2K)
Civic Si, Integra LS, and GSR all use the same pan. 11200-P30-010
Type R is different, 11200-P72-010.
Old Mar 16, 2006 | 06:16 PM
NJIN BUILDR's Avatar
Default Re: (95CXLS)
GSR is different than LS/B16.Its deeper and shaped a little different to clear the main girdle.The gsr pan and p/up will fit a b16/ls but not the other way.
Glenn
Old Mar 16, 2006 | 06:26 PM
Slappy's Avatar
Default Re: (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">GSR is different than LS/B16.Its deeper and shaped a little different to clear the main girdle.The gsr pan and p/up will fit a b16/ls but not the other way.
Glenn</TD></TR></TABLE>
I should have been a little more clear.....
94-98 Gsr is a 11200-P72-010.
99-01 Gsr is a 11200-P30-010
94-01 Ls is a 11200-P30-010
99-00 Si is a 11200-P30-010
Old Mar 16, 2006 | 06:34 PM
manekDC2.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95CXLS &raquo;</TD></TR><TR><TD CLASS="quote">
99-00 Si is a 11200-P30-010</TD></TR></TABLE>
will the 94-98 gsr pan work with a b18a??
Old Mar 16, 2006 | 06:49 PM
one slow coupe's Avatar
Default Re: (manikGSR)
if i have a gsr can I use an ls pan?
Old Mar 16, 2006 | 11:14 PM
riceball777's Avatar
Default Re: B series oil pans? (mportracer33)
there are 2 different b seris oil pans. they are seperated by engines that have block girdles and ones that do not. LS/b16/b20 oil pans are all the same. (no block girdle). then theres the gsr/itr/ctr oil pan when is stamped p72 on the bottom. you can use a p72 oil pan on a b16/ls/b20 but you cant use a b16/b20/ls oil pan on a car with a block girdle (gsr/itr)
Old Mar 21, 2006 | 11:46 PM
manekDC2.'s Avatar
Default Re: B series oil pans? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">there are 2 different b seris oil pans. they are seperated by engines that have block girdles and ones that do not. LS/b16/b20 oil pans are all the same. (no block girdle). then theres the gsr/itr/ctr oil pan when is stamped p72 on the bottom. you can use a p72 oil pan on a b16/ls/b20 but you cant use a b16/b20/ls oil pan on a car with a block girdle (gsr/itr)</TD></TR></TABLE>
thanks riceballs
ray on boost
Feb 17, 2009 07:56 AM
esoterEK..
Feb 22, 2007 09:36 PM
BuyImports2
Oct 19, 2005 10:33 PM
V8K1LLER
Jul 25, 2005 05:52 PM
underpressure02
Jun 28, 2005 02:38 PM
