Template EG Side Markers....
Old Mar 16, 2006 | 02:15 PM
JDM_SOHC's Avatar
Default Template EG Side Markers....
Anyone have a template cut out that i can print out an use on my fender for the EG flat side markers..??? I've searched an searched an all i can find is for EK bodystyle which are different than EG....... Please help thanks....
Old Mar 16, 2006 | 02:54 PM
usdmEHboy's Avatar
Default Re: Template EG Side Markers.... (JDM_SOHC)
http://www.clubcivic.com/board...34686
Old Mar 16, 2006 | 03:14 PM
Formula's Avatar
Hey thanks guys!
I'm repainting my EG soon and already bought the side markers. I was going to buy the two JDM front fenders but now I might just use my USDM fenders.
Old Mar 17, 2006 | 10:32 AM
JDM_SOHC's Avatar
Default Re: (wyte_civic)
did the dremel chip ur paint.... i heard i should tape it all off an ****???
Old Mar 17, 2006 | 10:38 AM
EvilPinkEye's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wyte_civic &raquo;</TD></TR><TR><TD CLASS="quote">its quite easy.. i used a dremel... and the templete then just wired it.. quite simple..</TD></TR></TABLE>
use the nibbler from radio shack...got mine for 5 sells for 15....slower, but cleaner
Old Mar 18, 2006 | 11:01 AM
JDM_SOHC's Avatar
Default Re: (EvilPinkEye)
truu i checked out that other template an its not the right one for mine... that one is for the EK version.... These are the EG Sidemarkers... they have that little tab that has to clip in so theres gonna be a little knotch on one side where that clip goes....
Old Mar 18, 2006 | 11:40 AM
h22HatchEG's Avatar
When i dremeld i used 2 layers of masking tape. 1 so i could make an outline, and 2 so it wouldnt chip the paint. And if you Dremel, id suggest using the good cutting wheels, the "waffle" style ones.
spintboy
Lighting
Dec 3, 2007 12:43 PM
91pearlcivic
Welding / Fabrication
May 3, 2007 03:26 PM
crxdude
Mar 26, 2007 07:36 PM
Japanda
Jan 23, 2007 08:35 PM
TuningOptions
10
Nov 29, 2004 02:07 PM
