What tranny do i have?
Old Mar 16, 2006 | 01:15 PM
VegaS10's Avatar
Default What tranny do i have?
My b18a1 came with the clutch and flywheel till attached. I'm cleaning everything for the swap. I pulled the clutch off the flywheel and it won't fit on the tranny shaft. The label on the tranny was removed for painting purposes (previous owner). I was told it was a 91 ls tranny, but, obviously not. . I counted 24 teeth on the tranny, and 24 on the clutch. It just seems that the clutch hole is a TAD to small.
Help so can order a new clutch!!!
Old Mar 16, 2006 | 01:55 PM
Runnerdown's Avatar
Default Re: What tranny do i have? (VegaS10)
it must be a 92 or 93 tranny then. they had bigger shafts. you need a 92-93 teg disc. the other stuff you can reuse.
Old Mar 16, 2006 | 02:43 PM
VegaS10's Avatar
I order the flywheel for the b18a1, and the clutch for the tranny...correct?
Old Mar 16, 2006 | 04:08 PM
Runnerdown's Avatar
Default Re: (VegaS10)
yeah, but all b-series flywheel are the same so no sweat there.
BlkCivicFromTeamMNR.com
Jul 26, 2007 11:53 AM
honcrx91si
Aug 14, 2005 08:56 PM
crxb20ed
Aug 14, 2004 11:52 AM
TeGGY_LS
May 16, 2004 10:36 AM
