91 DA speedo problem after cluster removal
Old Mar 16, 2006 | 12:05 PM
Sleepy_Red_hatch's Avatar
Default 91 DA speedo problem after cluster removal
so my bro takes the cluster out of his 91 DA to lube up the speedo cable/head, upon reassembly the speedo shoots up to 2 or 3 times the actual speed
anyone hear of this? whats causing it? thanks,
-SRH
Old Mar 16, 2006 | 12:14 PM
CaseBone's Avatar
Default Re: 91 DA speedo problem after cluster removal (Sleepy_Red_hatch)
Check the speed sensor!
Old Mar 16, 2006 | 07:57 PM
Default Re: 91 DA speedo problem after cluster removal (X92B18C1TegX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X92B18C1TegX &raquo;</TD></TR><TR><TD CLASS="quote">Check the speed sensor!</TD></TR></TABLE>
what do you mean? what am i looking for? it looks liek a speed sensor lol
Old Mar 16, 2006 | 08:00 PM
pro1342's Avatar
the cable may have popped out of the cluster, or out of the speed sensor. if the cable is connected properly, then the speed sensor gear might be screwed
Old Mar 16, 2006 | 08:05 PM
Default Re: (pro1342)
the speed sensor wasnt touched and teh cable is in the cluster tightly, when he did was put oil in the top of the speedo cable, held it up so it all ran down the entire lenght, put grease on the cable head and reattached everything and now it reads all whacky.
Old Mar 16, 2006 | 08:11 PM
pro1342's Avatar
make sure the clip is holding the cable in the speed sensor, the cable might have been pulled out when the cluster was pulled. that is about all i can think of other than replacing the cable.
Old Mar 16, 2006 | 08:19 PM
alright, will have a look in the morning, any other opinions?
Old Mar 16, 2006 | 09:22 PM
Default Re: (Sleepy_Red_hatch)
up.
Old Mar 17, 2006 | 07:48 AM
up, any more suggestions for when my bro gets home from work
Old Mar 17, 2006 | 09:31 AM
JETSPD1477's Avatar
i can only imagine the cable not being clipped onto the cluster properly... unless you damaged the cable in some way.... DA speedo cables suck as usual.
Old Mar 17, 2006 | 01:12 PM
dcRay's Avatar
Default Re: (JETSPD1477)
Check the speed sensor side of the cable. It must of jump out like the other member said.
Old Mar 17, 2006 | 03:07 PM
Spectrum24x's Avatar
Default Re: (dcRay)
Speed sensor is on top of tranny under intake manifold, not hard to get to..
Never heard of lubing the cable, could this lube cause it to spin too much? (sorry if thats a noob question)
Old Mar 17, 2006 | 06:25 PM
Default Re: (Spectrum24x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">Speed sensor is on top of tranny under intake manifold, not hard to get to..
Never heard of lubing the cable, could this lube cause it to spin too much? (sorry if thats a noob question)</TD></TR></TABLE>
nor have i, he works at a honda dealership and says it was recommended to him...beats me and thanks for the effort but i know where the VSS is, and so does he im used to my mmm...electronic one
TMC_EF
Jul 16, 2007 10:37 PM
beefjerky
Mar 11, 2007 08:45 AM
sacjdmz
May 17, 2005 09:03 PM
LAWST
Mar 3, 2005 06:51 PM
sleepin91teg
Mar 29, 2004 04:29 PM
