what are the wires coming off the fan switch? 12v + ??
on my fan switch connector on my 91 dx wit ls swap what are the wires that run to it? problem is i dont have the oem wires any more so can i just take a plug that fits on the fan switch on the thermo stat housing and run them to the fan ? if so how does that work . does one side of the switch wires go to 12v and the other side to + on fan motor? then just grnd other side of fan or what ?
so if i run a 12v+ to the + wire on cooling fan and the run a ground to one wire on the switch and from the other switch wire run it to the grnd side of fan will it work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Use a relay. Probably the fan motor draws more current than the switch would like.</TD></TR></TABLE>
x2
x2
SteelcityLude
Aug 27, 2011 02:46 PM
jry2598
Aug 28, 2006 10:19 AM
