SearcHed.......Odd smoking on DoHc ZC
After searching for an answer ive become a little puzzled..heres the problem...when starting the car no smoke is released....if i let it sit at idle for 5-8 mins then rev it..thats when a quick puff of white smoke comes out..but then thats it...i can drive it rev high watever and no smoke...but if i let sit idle for that ammount of time...always little bit of smoke...less when car is warm..i was thinking head gasket..and ive heard stories of pinched oil lines? any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoHcZC91si »</TD></TR><TR><TD CLASS="quote">After searching for an answer ive become a little puzzled..heres the problem...when starting the car no smoke is released....if i let it sit at idle for 5-8 mins then rev it..thats when a quick puff of white smoke comes out..but then thats it...i can drive it rev high watever and no smoke...but if i let sit idle for that ammount of time...always little bit of smoke...less when car is warm..i was thinking head gasket..and ive heard stories of pinched oil lines? any ideas?</TD></TR></TABLE> 1st off is the car boosted? if it is(which i think so based on the oil line staement) check your return line....if theres a slight kink in the line that would happen(i had that problem before) if the motor is na. i'd say it sounds like bad valve guides
aaa i c..well my car is N/a so im gona go with valve guides...but im not gona bother with fixing that..rather just build the head
k thanx for the info
drewcandraw
Aug 13, 2005 12:51 AM
YellowR2000x2
May 22, 2005 02:04 AM
