b-series bell housing question
Old Mar 16, 2006 | 11:02 AM
swatteamtimmah's Avatar
Default b-series bell housing question
i bought a gsr tranny off ebay and it was damaged during shipping, anyhow i currently have a LS tranny and are the bell housings the same could i just swap them?
http://honda-tuned.com/tranny/1.JPG
http://honda-tuned.com/tranny/2.JPG
http://honda-tuned.com/tranny/3.JPG
Old Mar 16, 2006 | 01:26 PM
tgreaves's Avatar
Default Re: b-series bell housing question (swatteamtimmah)
You need the swap the cases..
Old Mar 16, 2006 | 02:35 PM
West Werks's Avatar
First off thats not the bellhousing thats the tranny case. Secondly looks like both the tranny mount holes are f'ed and the small crack.... So you need at least the tranny case. But from the looks of the pix the bellhousing is fine.
p.s. by the way the bellhousing is the part of the tranny that the starter bolts up to, the part that attaches to the block....
Old Mar 17, 2006 | 11:41 AM
thanks for clearing that up, but is the LS tranny case and bellhousing compatible with the GSR case and bellhousing...can i just swap them both and will it be cool?
edit: i have a bad LS tranny so if i could just swap the case and bellhousing thad be super..
Old Mar 17, 2006 | 04:13 PM
IN VTEC's Avatar
Default Re: (swatteamtimmah)
You need to check the thrust clearance on the differential and mainshaft first before just bolting the casing halves together. If the thrust clearances are too loose, you could damage a bearing.
Old Mar 18, 2006 | 12:27 PM
Bense's Avatar
Default Re: b-series bell housing question (VenGeanceDrag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VenGeanceDrag &raquo;</TD></TR><TR><TD CLASS="quote">First off thats not the bellhousing thats the tranny case.</TD></TR></TABLE>
cause you know, there's a difference
dustinr182
Jan 9, 2007 05:41 PM
zhan28
Nov 20, 2006 04:45 PM
The G2 Racer
May 2, 2004 08:51 PM
